Results 1 to 8 of 8
    Apr 2007
    Eastern Ontario
    97
    Default Pipe Bender - Worth it?
    I need to bend some 1 1/2" pipe (sched 40) for a project for my son. It's a one off project and I need to make 6 x 90 degree bends. They are NOT structural.
    I know I can slice the outside half way through, make the bends and weld up the outside, but I see the $99 and $149 Pipe benders (bottle jack, saddle and roller version) and I wonder if they are worth the $99, given they come complete with saddles for several different pipe sizes?
    I'm not adverse to spending the money if they work well, as I'm sure I'd use it again off and on, but I hate spending money on something only to be frustrated trying to use it.
    Good, bad, save my dough, wouldn't be without it?
    Tips and tricks for using one?
    Things to look out for?
    Jul 2008
    Uruguay, small pacific country with south Altantic coasts, 3 million friendly people population.
    89
    Hi Eddie, for pipe benders I have been told to fill the tubes with sand, and compress it tightly with wood caps on both ends of the tube. Also the bender should match as perfectly as possible the section of the tube.
    Hope this helps.
    Regards:
    Jerónimo.
    Browns Valley, California
    1,713
    Big Eddy,
    I bought one of those from Northern Tool a year ago. Only needed it twice so far, but I'm glad I had it when I needed it! It is the bottle jack type you referred to, and it worked fine. I had to squiggle a length of black pipe around a couple of demolition-only removable rocks, and the bender worked sweet.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Jan 2008
    VA
    298
    The saddle and roller type work OK for non race cage type stuff. They will leave dents on the back of the pipe where the rollers contact. More so with thinner wall tubing like .120 or .95 I made a set of saddles from the next size pipe up from each size. They keep the rollers from denting and deforming the pipe on the outside. Cleaning up the bender saddle face helps too. Most are rough castings and I found that you can grind them some to clean up deepen them some and this makes an almost mandrel like bend.
    4,246
    I have went down and bought rigid conduit sweeps for one off jobs too. Already bent flawlessly.
    alabama
    713
    Would 90 degree pipe elbows work? they can be bought for about 5 dollars each.
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    Jan 2008
    haslet, TEXAS
    109
    those work great for 90 degree bends! I just folowed this.
    http://youtube.com/watch?v=GWT3N3m4bE4&feature=related
    Jul 2008
    Avondale, AZ
    104
    There not a bad buy, I bought one and used it to Fab up half of a long travel golf cart project. The key as was stated above is fill the pipe with sand so it doesn't collapse, although we just duct taped the ends and it worked fine.
    If your not opposed to spending a little money check into a JD squared, that's the one I have now and it seems like it was about $225 or so with an 1 1/2" die from tricktools.com if you plan to do more it's worth it just for the speed and not having to fill each pipe with sand.
    Ok they went up a bit but still worth the investment if you plan to do more bending
    http://www.vansantent.com/model_3_bender.htm
    Here's the link
