Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 68
  1. #51
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Hey ANDY......still waiting for those #'s.....or did you overstep a little with the sales dept??
    That is a possibility!!!
    I would also be interested as I plan on getting one in the coming months (sooner if I get this fair sized aluminum job).
    at home:
    2007 302 Trailblazer with the Robin SOLD
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
  2. #52
    Sorry guys...
    Been on the road again the last 3 weeks.
    The serial numbers of the new style Dynasty 200s are LJ280222L and later.
    Happy shopping!
    Andy
  3. #53
    Nov 2007
    1,270
    Thanks Andy!
    Now if this guy would commit to this large project I'll be heading to my LWS pronto!!!
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
  4. #54
    Lake of the Ozarks MO
    3,596
    Thank you very much Andy...I needed that.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
  5. #55
    Nov 2003
    3,824
    Default Thank You All
    Guys and Gals + of course Andy
    thank you all for a spirited and interesting discussion
    take care
    Heiti
  6. #56
    2,967
    October 24, 2008 - Suited for portable applications, Dynasty® 200 AC/DC TIG/Stick and Maxstar® 200 DC TIG/Stick Power Sources feature Blue Lightning(TM) technology, which provides reliable high-frequency arc starts over input range of 1-200 A. Operator enters chosen tungsten size from 0.020-0.125 in., and Blue Lightning sets optimal starting parameters. In addition, Dynasty 200 features advanced AC waveforms to optimize arc characteristics for various applications and operator preferences.
  7. #57
    Nov 2007
    231
    From 8/4/2008, post #28:
    "The HF starting appears to be one of the areas which the new version will address. Previously there was a single default start setting used erroneously by many for all different kinds of tungsten type and size, but which was intended for 3/32" diameter ceriated. I wouldn't say that the previous versions had problems as much as I would say the user didn't take the time to understand how to setup the machine properly--by reading the owner's manual. Sure you can just crank up the starting amperage and start duration, and it will light off just fine. The problem becomes undue wear on the tungsten. So the best compromise between consistent starts and long tungsten life becomes adjusting the parameters to only as much starting amperage and time as is necessary. For the comment about the syncro250...remember that HF is applied for both starting and continuous operation in AC mode, whereas it is only used for starting on the Dynasty model.
    The new model appears to still have the generic starting mode for 3/32 dia. tungsten, but goes further by providing pre-set start parameters based upon the user's selection of tungsten diameter: 0.020, 0.040, 1/16, 3/32, and 1/8.
    In addition, the range of starting adjustment has grown from being start amp, start time to start amp, start time, slope time, and min. amperage. So for those who hate to make adjustments other than the big dial for amperage, your best bet will be just to select the correct diameter of tungsten and that should give you good starts.
    On another note, there also appears to be the ability to select different AC waveforms. Previously, AC was defined as 'Advanced Squarewave'. This offered a lot of puddle agitation due to its nearly vertical transition between DCEP and DCEN. Some in the past complained about silicon freezing in the puddle and giving a less than shiny final bead. Now you'll be able to choose the 'Soft Squarewave' which slows down the transition rate between DCEP and DCEN and provides less silicon freezing and better wetting at the toes of the bead. For the old-school users, a true sinusoidal waveform can be selected, as well as a triangle waveform.
    -dseman "
    All you need to do is read the owner's manual and you'll find out all you want to know. It's very simple.
    -dseman
  8. #58
    2,967
    I was just posting that there is called Blue Lightning
  9. #59
    Jan 2006
    Eugene, Oregon
    2,428
    http://news.thomasnet.com/fullstory/551224
    Dynasty 350DX
    Dynasty 200DX TigRunner
    MM 350P
    MM Passport Plus
    Spectrum 375 Extreme
    08' Trailblazer 302
  10. #60
    3,596
    Nice link KB...thanks
    Miller WC-115-A
    Miller Spectrum 300
