Thread: airco ac welder
    Jul 2008
    Default airco ac welder
    I have an airco ac heliarc high frequency welder. I am told it is made by miller and looks like the 320 or 330 model.can it be converted to dc also to tig weld steel?
    Mar 2008
    Dallas,Tx
    172
    Default Airco Tig
    You can tell very quickly by the serial number if Miller built it but I don't recall AC only machines of the 330ABP vintage even though Miller did build AC only Syncrowaves. While you could add the rectifier and stabilizer from common scrapped machines, the work involved and the fact that nice AC/DC 330ABP's are available on the used market reasonably might make that option more attractive to you. weldersales
    Jul 2008
    Default airco welder
    the model # is 253 H.A.P. it doesnt say on the machine if it's a/c or d/c
    it's an airco 253 heliarc high frequency welder the ser# is 12211
    8,209
    After looking at a picture of one, I don't think Miller or Lincoln made it. Alot of firms used the "Heliarc" name. ESAB ended up with it
    Maybe its a true Airco, P&H, or even possibly an old ESAB
    Sep 2008
    4
    Default need info on older miller blu star
    I have Miller blue star ser#hh096695 w/ a 16hp kohler k seris engine . It sat in a warehouse for years. I put a carb kit fuel tank,plug and fuel in it and got it to run( a little rough back fires once in a while) but can't find any info on this machine and i'm not real sure where to look
    8,209
    Quote Originally Posted by cwilliams View Post
    Well thats easy, just look in owners manuals, and pull up a Bluestar 2, it'll have the 2E listed there for your serial # as well.
