Results 11 to 16 of 16
Thread: Lead Weights
    Traer, IA
    317
    Quote Originally Posted by Vicegrip View Post
    Toss a small chunk of beef tallow or a strip of raw bacon on the top of the molten lead just before you want to pour. Stir the lead around as the fat smokes and burns off and it will lump all the slag up and make it easy to skim off. Lead oxide is the bad for you part. Be carefull of the gray crud it is very bad for you stuff. I saw a good trick the Porsche road racers use. They took a right side floor pan from a car and used it as a mould. Made weights that fit like a glove to the floor. They were easy to bolt tightly in place and the weight was as low as legal for a better COG.
    Thanks for the advice from you and everyone else. I'll definately do it outside with a fan blowing everything away from me
    Traer, IA
    317
    Quote Originally Posted by BudMan580 View Post
    How are you fastening the weights? When I was racing karts, used tuna cans and a torch, 5 lbs. each, but I placed a bolt in the the can before pouring in the lead. I know you're talking alot more weight, but think about where it's going and how you're fastening it. I know a guy who was racing "blunderbust" cars at the local track. He "tubed" his chassis and slid the weights inside. Had holes at different locations in order to lock the weights where he wanted, with thru bolts or threaded rod.
    Whatever you do, DO NOT, I repeat, DO NOT try to cool your weights by dunking them in water, a friend of mine almost burnt his face off with the ensuing explosion!!!!!!!!
    I think I'm going to weld up a form that is 2"X3"X12". We will drill a couple of holes thru the weights to mount them to the tubing frame of the car. That way we can stack them a couple of weights thick where needed. The weight brackets mount around the tubing and have a 1/2" peice of all-thread rod sticking out of them. I'll take some pics when I get them done. Thanks for your help!
    Oklahoma
    720
    Paraffin (also known as Gulf wax) also works good for flux when melting/casting lead. Beeswax can be used but the wax is more convenient.
    Griff
    Feb 2008
    North of Phila. PA
    404
    You are in for a treat drilling thru the lead. It tends to load up on the drill bit. I have had mediocre success drilling lead weights. For the dive weights I make I have 2 tapered pins in the mold at the location I want the holes. This saves me from drilling those. Several others have holes in odd locations and unfortunately those I have to drill. I want to try and coat the drill bit the next time with wax and see if that helps at all.
    Northern California
    205
    Default Lead weight.
    It's a good idea to weld up a casing of the size and shape that will fit in your car. The dimensions can be determined by the weight you need. I don't have my reference book with me but there is a certain weight per cubic inch of lead. That will tell you what size casing you need.
    The suggestion by DSW up above to melt the lead into your form is a good one. Pouring lead can be extremely dangerous. It's heavy and unwleidly and you could spill it. If you melt in your form, there's no pouring required and you don't have to go back and forth with the molten lead.
    I recently built a weight for my Harley sidecar that sits on the outer spring perch. There are four 7/16" bolts holding it down. The casing was welded up from 1/4" mild steel plate. The inside dimensions are roughly 3" X 4" by 12" long. With the weight of the lead and the casing and some calculations I came out at almost exactly 50 pounds, which was my target weight. Harley used to sell a sidecar weight that was made out of cast iron but they are no longer available.
    Once the empty casing was welded, I set it outside on a board and leveled it. I filled it with my lead which was previously molded into 2" square bars. These I cut into 4" sticks. I used a Harbor Freight roofing torch that hooks to my BBQ propane tank. That baby really puts out the heat!
    The lead was fairly clean and once it melted I had to add about three more sticks to fill to the top. It cooled to where I could handle it in about an hour and a half and later on, I drilled the four holes. As DSW says, drilling in lead is not easy. If you go slowly, it's not too bad. You have to lift the drill from time to time and clear the lead from the drill.
    Good luck.
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Quote Originally Posted by Champagneracing View Post
    If I remeber correct one stock valve cover makes a 23 lbs piece of lead.
    I thought you were right but I guess we were both wrong. Tonight we were moving some lead around on our race truck and we had 53lbs written on one of our chevy valve cover weight blocks. I didn't believe it so I took the time to unbolt it and weigh it... yep 53 lbs!!!
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
