Results 1 to 10 of 16
Thread: Lead Weights
    Traer, IA
    317
    Default Lead Weights
    Does anyone here know what the best method of making some lead weights would be? I need to make around 150 pounds of weights for a USMTS Dirt Modified. I've got six 5 gallon buckets full of wheel weights. Any ideas?
    3,927
    An old gas stove and some old pans. My daughter tested postive for lead poisioning years ago so that ended my bullet making in the house so i would do it outside if possible. You can also use a torch but it takes a little longer unless you have a rosebud. I made a barbell weight set years ago and used round steel cake pans for the molds...Bob
    Quote Originally Posted by willy View Post
    Willy most guys take a small block chevy vavle cover weld up the breather hole and use that as a mold. You then load up the cover with them weights and take a rose bud to the weights and melt them all tell they all turn liquid(outside cause they will smoke). If I remeber correct one stock valve cover makes a 23 lbs piece of lead.
    Feb 2008
    North of Phila. PA
    404
    I have a couple of things I use to melt lead for weights.
    I have a plumbers propane pot, but a propane gas ring or turkey fryer burner works great and is a lot cheaper. I also run a propane weed burner as an auxilery heat source to help heat the top to get the weights started.
    My "pot" is the bottom of an old steel welding tank I snaged from the hydro shop as dead. About 10" across and 8" high. My small pot is a chunk of steel pipe with a 1/2" plate welded to the bottom. Both work better than the small iron plumbers pots that I used to use.
    As a mold I have several chunks of C channel that I welded ends on. The ends are sloped so the lead drops out easy. I have also used cupcake pans. I have had some issues with some lead sticking to the cake type pans if it gets too hot. Sort of solders itself to the steel.
    I usually melt down some clean scrap to get a puddle in the pot than start adding in junk mixed with crud. I add extra heat to the top with the weed torch and skim off all the steel, copper, or what ever. I use a metal pasta scoop, A large perferated spoon and a laddle that I picked up from the dollar store to clean the lead and do small pours in sinker molds and dive weight molds. The extra I pour in to the Cchannel molds as clean ingots for later use.
    I try ang pour almost all the lead from the pot before I quit. The large mass in the pot is to hard to get started otherwise.
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Quote Originally Posted by Champagneracing View Post
    I think your right, if I remember I'll check when I'm out in the shop tomorrow night, we should have one laying around.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Queens NY
    1,547
    too bad none of you huys is close to NYC, i got a bar around 80-100lbs sitting in my back yard. Couldn't let a friend throw it out !!
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    3,927
    Quote Originally Posted by Laiky View Post
    I just scrapped close to 500 lbs of old bullets and got 245 bucks out of it. I remember when it brought a nickle a lb scrap...Bob
    Jan 2008
    VA
    298
    Toss a small chunk of beef tallow or a strip of raw bacon on the top of the molten lead just before you want to pour. Stir the lead around as the fat smokes and burns off and it will lump all the slag up and make it easy to skim off. Lead oxide is the bad for you part. Be carefull of the gray crud it is very bad for you stuff. I saw a good trick the Porsche road racers use. They took a right side floor pan from a car and used it as a mould. Made weights that fit like a glove to the floor. They were easy to bolt tightly in place and the weight was as low as legal for a better COG.
    Jul 2008
    Long Island, NY
    19
    How are you fastening the weights? When I was racing karts, used tuna cans and a torch, 5 lbs. each, but I placed a bolt in the the can before pouring in the lead. I know you're talking alot more weight, but think about where it's going and how you're fastening it. I know a guy who was racing "blunderbust" cars at the local track. He "tubed" his chassis and slid the weights inside. Had holes at different locations in order to lock the weights where he wanted, with thru bolts or threaded rod.
    Whatever you do, DO NOT, I repeat, DO NOT try to cool your weights by dunking them in water, a friend of mine almost burnt his face off with the ensuing explosion!!!!!!!!
    Traer, IA
    317
    Cool Hmmm
    I guess I should cash the weights in - I can gaurantee I'll make more money at that than racing
