    Sep 2007
    Medford MA
    525
    Default Cast Iron Garden Art Welding
    Hi
    This past weekend I managed to acquire a pile of pieces from an old
    "cast iron stove". I'm planning to turn these into some garden art.
    I know that welding cast iron requires special techniques to prevent
    cracking. Is it ok to mig or fluxcore the material and not bother
    with the special procedures? Or would the cracking be so bad that
    i'd end up with nothing but a pile of sh..?
    The things I'm planning to make will have no safety issues. Nothing
    structural, or the like. I'm talking things a foot or two high, not have
    to carry any loads...
    Also, while I think of it, some of the work may want to have some
    additional pieces to hold it together -- again, with the same low
    quality expectations, can I weld cast iron to plain ol carbon steel?
    My welder is a MM140 -- I do expect to do a lot of grinding and so on
    to get to clean metal (if there is any?!?!) once I start the project.
    Thanks in advance
    frank
    now in Orlando!!!!
    557
    fjk, just knock the paint off and go for it, do some tests and see if it breaks when you wack it with a hammer, do not be afraid of putting some heat to it, see what it will take, lets see some pictures when you are done, best regards,Paul
    More Spark Today Please
    May 2008
    Austin Tx.
    101
    I have put some things back together like that with a mig.
    Not like garden art gets a real work out.
    Brass works too.
    Randall
    Feb 2008
    California
    51
    You shouldn't have much of a problem, as long as it isnt somethign structural. If you do have a problem, just hit it with a torch for a while before you weld.
    Read or submit reviews of Lincoln, Hobart and Miller Welders atThe Welder Shop.
