Here's some pics from the home-shop.....first project of this size at home....
getting used to the welder:
A few of the overall project:
Thread: First job with my 12VS
07-09-2008, 07:14 AM #1
- Jun 2008
- 26
07-09-2008, 01:50 PM #2
- Jan 2008
- VA
- 298
False bottom for a dumpster? I hope the dope smugglers that hired you don't see this thread!
07-10-2008, 06:23 AM #3
- Jun 2008
- 26
HA!!!...Naw....its a for draining water out material so that it goes to the landfill dry which makes it non-hazzardous waste and saves cost in weight....still have a lot more work to do - have to put in drain ports and sides will get similar treatment and screen floor / expanded metal sides have to go in....when it's all done we figure it will be about 1/3 of the cost of buying one factory made.
07-10-2008, 07:57 AM #4
- May 2008
- Belle Plaine Iowa
- 233
Id rethink the screen bottom or use of expanded metal. Thats just a great way to make the load stick and not unload mo matter how high you tip it. How about solid sheet floor with several holes instead? I like the idea of letting the rain water out.
07-10-2008, 08:53 AM #5
- Jun 2008
- 26
It should work fine since we basicly copied all the spec's -- right off the sales cut sheet of the factory made ones
....the other factor is (that I didn't mention before) is you put a fabric liner "bag" inside which will also help it slide out.
07-11-2008, 05:49 PM #6
- Mar 2008
- 60
What setting did you run at?
I have one getting ready for it first run next week and was wondering what you used as a starting point.
07-14-2008, 10:18 AM #7
- Jun 2008
- 26
I'm sure some of the real pro's around here will be able to tell ya better how to get setup right, and maybe I'm running pretty far out of those parameters, but this is what I did........I started with the settings listed inside the lid on the VS and had trouble getting a good start on the arc, had a lot of spiutting and wire skipping around. So, I adjusted the supply power the Trailblazer up some and the wire speed up a lot got it going with good starting and consistant beads. The VS reads about 31 volts when idling, but goes down around 25 when welding. The wire speed is up around 315. That's when it all started looking like that top picture bead.
07-16-2008, 06:02 AM #8
- Mar 2008
- 60
Thanks for the heads up. I really like using the the RC feeder with the Trailblazer this setup will be on a Bobcat and I need to get used to it so prictice time is this week in a non structural job.
Thanks again.
07-19-2008, 06:04 PM #9
- Jun 2008
- 26
Here's a little more:
