Results 1 to 10 of 13
Thread: Tigger cart
    Jul 2006
    alaska
    181
    Default Tigger cart
    OK Gentlemen let me have it, how am I doin. Built this on leave for my 200DX which I love, getting out of the Army after 24 years (20 Active) and just want to weld. give me some pointers, Thank you.[ATTACH]hsbToRgb[/ATTACH]
    [ATTACH]rgbToHsb[/ATTACH]
    [ATTACH]hexToRgb[/ATTACH]
    [ATTACH]rgbToHex[/ATTACH]
    [ATTACH]associate[/ATTACH]
    [ATTACH]extend[/ATTACH]
    [ATTACH]test[/ATTACH]
    [ATTACH]remove[/ATTACH]
    [ATTACH]copy[/ATTACH]
    [ATTACH]each[/ATTACH]
    [ATTACH]indexOf[/ATTACH]
    [ATTACH]some[/ATTACH]
    [ATTACH]every[/ATTACH]
    [ATTACH]map[/ATTACH]
    [ATTACH]filter[/ATTACH]
    [ATTACH]forEach[/ATTACH]
    Jul 2006
    alaska
    181
    Default Crazy stuff
    Why is all that extra writing in there? It did this with the pics that BTW are at the bottom.
    CT.
    333
    Nice little design there11b. You have too much "cleaning",by the too wide white area around the weld. What are your settings. Turn up the balance a little more and turn up the Freq. higher too. I was doing the same thing you were till someone on another site has a Dyn 350 and told me to run the balance in the high 70's with the frequency over 200Hz. It really works good.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Nov 2005
    112
    Default Tigger Cart
    Nice I Will Biuld Mine Similar Look At My Torch And Hose Hanger And You May Use It For Hood And Tig Torch May Have To Modify From Oxy Acetylene To Tig Torch But He Principal Is The Same
    Aug 2006
    near rochester NY
    9,881
    Thumbs up
    great looking lil cart.
    you may find you want to angle the Dyn up or add a higher shelf to put it on. if you do a lot of work at your welding table you will always be bending down to set or read the welder. mine is about 28" off the ground and works well for me, but to each his/her own. the best part about building your own cart, is you get to play with it and change it to suit you as you feel the need. man its cool to have welders.
    S.W. Pennsylvania
    2,250
    Nice little cart, but I'm more impressed with you're service to the country.
    Thanks.
    Jame's suggestion about adding a shelf to get it up higher might make life a little easier.
    To all who contribute to this board.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Jul 2006
    alaska
    181
    Hey thanks for all the suggestions. I had the balance set at 80 and the freq set at 160 hertz so maybe as one member said turn the freq up? Oh and I just may build a shelf for the welder but over all the welds are good yes?
    Aug 2006
    near rochester NY
    9,881
    Thumbs up
    they look solid. it takes time to get the sweet looking welds with consistent ripples. you will get there if you hang in there. getting a good solid holding weld is the first hurdle, looks will come with time......for me lots of time it seems.
    Jul 2006
    alaska
    181
    OK Thanks and I love that torch holder! I like small projects.
    Jun 2008
    Billings, MT
    114
    Default Nice Cart
    Nice cart!
    I don't TIG but welds look ok to me....
    Thanks for your service!
    Miller 140 w A/S
    HF 90 Amp Flux Core
    Dewalt Chop Saw
    Smith O/A Torch
    Ryobi, HF grinders
    Harley Electra Glide Classic
