Results 1 to 10 of 10
    Jun 2008
    Montréal, Canada
    12
    Default First post : trailer question
    Hi everyone !
    I've made this little trailer to haul a Honda VTX 1300.... and I found it a little "weak". Here's the pics :
    A senior member help me and now, that's the result :
    All the frame is angle 2X2 - 3/16... Tongue and Center cross member "C" 1X2 - 3/16... Center tongue angle 2X2 - 3/16.
    TIG welded all around.
    What do you think ?
    sorry for my english... i'm a frenchman !
    Alberta Red Deer
    373
    looks like u did a good job of reinforcing the bed. it looked quite weak in the first couple of pics. good job, looks great. may be next time instead of angle iron use all box tubing it will be even stronger yet.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    Louisiana
    87
    Yep definite improvement on the last two pics, looks pretty strong. My hat is off to a man who TIG welds a whole trailer, I always wanted to do that but never had the time.
    Jun 2008
    Montréal, Canada
    12
    Quote Originally Posted by BDJ View Post
    thanks, you're understand that i don't welding for a living...
    2,641
    What Tires are those? Seems wide for trailer or any Road tires??
    Jun 2008
    Montréal, Canada
    12
    Carlisle 18.5X8.50-8
    MIRABEL , QUEBEC , CANADA
    50
    Salut
    PREND TOUJOURS DU TUBE CARRE 2X2 POUR FAIRE UN FRAME ET TON ATTACHE , TU PEUX PRENDRE DU FER ANGLE POUR LES TRAVERS , MEME SI LA REMORQUE EST PETITE , C'EST TOI QUI LE FAIT DONC PROFITES EN POUR LE FAIRE PLUS FORT , JE VAIS T<ENVOYER DES PHOTOS DES REMORQUES QUE J'AI FAIS QUAND JE VAIS ETRE A LA MAISON .
    BOBBY
    FABRICATION-CRÉATION K ZEN
    MILLERMATIC 210
    SPOOLMATE 3035
    SYNCROWAVE 200
    HYPERTHERM 360
    Jun 2008
    Montréal, Canada
    12
    Quote Originally Posted by k zen View Post
    Salut
    I know, that's the first and last time that I use angle iron. I like my trailers...overbuilt !!!
    Florida, USA
    3
    Thumbs up
    Your choice of angle is wrong, I know, I did the same mistake.
    Get a piece of 8" channel for the center and bolt/weld it to your frame and you will love your trailer.
    May 2008
    Belle Plaine Iowa
    233
    Are those road tires? They look like something off a lawn mower.
