Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Jul 2008
    Delhi, Ontario:
    1,998
    Question S.S Mig, Solid Wire !
    Quote Originally Posted by Frank Motoweld View Post
    Norm,
    if you want help with uphand solid wire steel or ss let me know.I'll show you the ancient frenchman secret technique LOL.You'll quickly make it have the stack of dimes look,just like i was talking about when i called you,Frank
    Frank Hi;
    What's Your secret Technique? As far as this Small Job, It's only about 12"
    Long, Sink Divider . I'll just try carefully to Mig it with S.S. Mig Wire ?
    .......... Norm
    P.S. Frank I respnded to your P.M, Not sure If it went through ?
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
  2. #22
    May 2009
    Ottawa Canada
    494
    Default Zee secret?
    Hi Norm,friendship buddy old pal,the ancient frenchman secret technique has been sent in your company's email.And no it will not self destruct after opening LOL,Frank
    Millermatic 252
    Millermatic 180
    Hobart spoolmate 3035
    Digital Elite
  3. #23
    Mar 2009
    NYC
    50
    and dont forget sheild gas up to 30, it helps a lot when miging stainless
    DYNASTY 350 DX
    DYNASTY 200 DX
    MILLERMATIC 251
    1942 MONARCH CK-12 LATHE
    1969 BRIDGEPORT J-2 HEAD MILL
    SCOTCHMAN 350 COLD SAW
    DAKE 200 BENDER
    BEAUMONT METALWORKS KMG BELT GRINDER
  4. #24
    May 2009
    Gulfport, Florida
    440
    Question To flux or not to flux that's the question
    It don't seem like using a flux cored stainless wire is all that great, especially for a large water fountain. you would have a lot of cleanup to do. And in my opinion flux cored wire is not as good to use on the thin stuff as solid wire. You know you can rent a tri-mix bottle by the month, that's if you did not want to by one for keeps.. I wish you the best on completing your project(s)....Bob
  5. #25
    May 2009
    Gulfport, Florida
    440
    Smile Food Grade Stainless
    Quote Originally Posted by davedarragh View Post
    Hey Norm: Food grade is usually 316 isn't it?
    FCP-316L is all position EXCEPT vertical down.
    What kind of wire do you have?
    The Federal Bankruptcy Judge ordered both sides to a Mediation Hearing on May 27th.
    The drama continues................
    Dave
    I know of only two food grade stainless, 304 and 316. There may be more but thies are the most used..
  6. #26
    Oct 2013
    24
    does not have to be tri mix gas but it would be preferred
  7. #27
    Oct 2013
    24
    flux core stainless wire burns to hot foe welding thin stainless hard wire would be better
  8. #28
    Oct 2013
    24
    the ancient frenchman secret is trigger it
  9. #29
    Wa
    643
    You just responded to a question from '09.
  10. #30
    Aug 2004
    Milan Michigan
    1,836
    Dave Derag, Alot of counters are mostly made out of 304 stainless, I use 316 wire which is acceptable.
    Nfinch96, You might have some problems on that thin stainless, If your going to try to mig it I would like to suggest .023 wire.
    Remember that your welds need to be smooth so food does'nt get caught in the weld ripples which can hold bacteria.
    I personally like to tig weld all restauarant stainless and buff it to a #4 finish to match existing.
    Unfortunately what happens about 20% of the time is the restarant tries to go cheap and I've had guys braze the stainless, arc weld it and mig weld it and I get the call to fix it because the health department says its not good enouph.
