Results 11 to 20 of 30
    Jul 2008
    Delhi, Ontario:
    1,992
    Exclamation S.S. Mig Gas ?
    Quote Originally Posted by davedarragh View Post
    C-25 or 100% CO2 can be used with most types of gas shielded flux cored SS wire.
    98% argon/ 2% O2 for metal cored
    SS MIG wire, depending on type, uses 95/5 CO2, 97/02 or Tr-Mix 90H/7.5Ar/2.5 CO2 for short arc and 98 Ar/ 2% O for axial spray transfer.
    Know your metals and your wire for correct application
    Dave
    Dave, I'll be doing a small restaurant job ( cracked dividers S.S. ) and I'll be using C-25, Should be allright small downhand Welds ? ( In a Sink )
    P.S. , Here anything about the Hockey Team- Bankruptcy hearing today ??
    ............... Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Oct 2007
    2,949
    Default SS MIG & NHL Follies
    Hey Norm: Food grade is usually 316 isn't it?
    FCP-316L is all position EXCEPT vertical down.
    What kind of wire do you have?
    The Federal Bankruptcy Judge ordered both sides to a Mediation Hearing on May 27th.
    The drama continues................
    Dave
    "Bonne journe'e mes amis"
    Jul 2008
    Delhi, Ontario:
    1,992
    Dave
    Dave, I'll be using 308L hard wire !
    Mediation Hearing? Crazy I Say Crazy !! You watch Bettman will Keep them In
    The U.S.A., He's an IDIOT !!
    .... ........... Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
  4. #14
    Oct 2007
    2,949
    Default SS MIG Wire
    Hey Norm: 308L is for "18-8" (304) steels. It calls for Tri-Mix in short arc transfer. 90% He/ 7.5% Ar/ 2.5% CO2.
    Vertical Up and overhead (3F, 3G, 4F, 4G, 5G, 6G) for solid SS MIG wire.
    Yeah, Moyes owns Swift Transportation (they probably run up your way), and rumor has it, he's had some financial issues for a while now.
    We'll see where the ice melts, and refreezes.
    As they say "The Puck Stops Here"
  5. #15
    Jul 2008
    Delhi, Ontario:
    1,992
    Dave; Well, It's a Small Job, and 308L & C-25 are what I have ! There's No Way I'm buying Tri-Mix for this small job !
    Ya, Bettman is trying to say the N.H.L. took over control of the team last Nov. - Dec./08 . We'll have to wait & See what happens. But there is No Way He'll let that Team come Back to Canada, It was in Winnipeg till "96" I think !
    ................ Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
  6. #16
    Jan 2008
    very eastern MA
    114
    Quote Originally Posted by nfinch86 View Post
    Id tig it
    the co2 will help the weld rust over time
  7. #17
    Mar 2007
    Deltaville, VA
    2,239
    Hey Dave,
    Know it's a typo but you may want to check your tri-gas mix in post #10.
    I "hope" some newbie doesn't try a 90% Hydrogen mix.
  8. #18
    Oct 2007
    2,949
    Quote Originally Posted by SundownIII View Post
    Hey Dave,
    Sundown: Hey Thanks, forgot the "e"
    Hopefully no one will try it, I doubt if they could find anyone to fill that recipie!
    Thanks again, I think I need to clean my keyboard!
    Dave
  9. #19
    Jul 2008
    Delhi, Ontario:
    1,992
    Quote Originally Posted by gordfraser View Post
    Id tig it
    I Do Not Tig.!
    ............. Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
  10. #20
    May 2009
    Ottawa Canada
    494
    Default Vertical up hand?
    Norm,
    if you want help with uphand solid wire steel or ss let me know.I'll show you the ancient frenchman secret technique LOL.You'll quickly make it have the stack of dimes look,just like i was talking about when i called you,Frank
    Millermatic 252
    Millermatic 180
    Hobart spoolmate 3035
    Digital Elite
