Results 1 to 10 of 30
Hybrid View
    Default Can I mig weld stainless steel
    Hello,
    I am pretty new, and wanted to see if I can Mig Weld stainless steel. Are there any tricks and can anyone point me in the direction of some instructions on how to setup for it?
    Thanks,
    Mar 2008
    Baltimore, Maryland
    315
    What machine do you have? What type of stainless are you welding? You must use tri-mix and it does cost a lot more then 75-25 mix. Plate, pipe, thickness. It's easy to weld with the right set up. IMHO.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
    Default Over my head!
    I think I am over my head on the stainless idea. I am running a millermatic 172 setup for steel. I think it is a 75%/25% argon mixture.
    I was told to use a flux core wire to make my life easier, and was hoping I could do the same with Stainless.
    I am only looking to weld small decorative items, like a 2'x3' fountain with pretty thin metal. I also thought about using it for highlights on a gate I am building.
    Jun 2008
    davie, fl
    13
    just switch your wire and weld if you dont have tri mix try welding with 25/75. stainless steel welds just like steel. if you arent sure just try it on a couple pieces of scrap. your machine is fine and has the same capacities for stainless steel as for steel.
    Aug 2006
    Browns Valley, California
    1,713
    If you don't care about the welds rusting, just weld it with ER70S-6 and C-25. If you want to keep the rust away, I'd get a small roll of ER309L and still use C-25.
    I've welded SS with C-25, and it turns out OK for small stuff. If I were going to get into serious SS fabrication, I'd probably want the helium/argon/COČ tri-mix, but I'd sure run a coupon or two first before I bought another gas cylinder!
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Victor O/A "J" series, SuperRange
    Mar 2007
    3
    Default gas mix
    has anyone tried argon/ 2% co2 ?
    as per Ed's suggestion: http://www.weldreality.com/stainlesswelddata.htm
    I'd be curious to see what the welds look like from a mig (like mine: 210 miller)
    Thanks!!
    Jack
    Salem ,Ohio
    3,972
    Cool
    Quote Originally Posted by jackflash View Post
    Thanks!!
    Jack
    Nope never tried it. I don't need anymore bottles and i don't do that much of it. But if i had a mixer that would be pretty easy since i have those bottles...Bob
    Feb 2012
    Wa
    670
    You just responded to a question from '09.
    Aug 2004
    Milan Michigan
    1,890
    Dave Derag, Alot of counters are mostly made out of 304 stainless, I use 316 wire which is acceptable.
    Nfinch96, You might have some problems on that thin stainless, If your going to try to mig it I would like to suggest .023 wire.
    Remember that your welds need to be smooth so food does'nt get caught in the weld ripples which can hold bacteria.
    I personally like to tig weld all restauarant stainless and buff it to a #4 finish to match existing.
    Unfortunately what happens about 20% of the time is the restarant tries to go cheap and I've had guys braze the stainless, arc weld it and mig weld it and I get the call to fix it because the health department says its not good enouph.
