Results 1 to 10 of 256
Thread: Miller's new Tig
06-25-2008, 10:51 AM #1
Miller's new Tig
06-25-2008, 11:18 AM #2
- May 2005
- 600
thanks Ed, i just puked on my keyboard.
06-25-2008, 12:15 PM #3
I couldn't see how much it is gonna cost. Is it the new econo-tig or what?
JamesMiller Dynasty 200DX SOLD
WeldTec Water Cooler SOLD
Miller Millermatic 180 w/ Spoolmate 100
20Ton press
And lots of Cut-off and grinding wheels
www.IAGPERFORMANCE.com
06-25-2008, 01:36 PM #4
- May 2005
- 600
06-25-2008, 01:50 PM #5
- Mar 2006
- Queens NY
- 1,547
06-25-2008, 01:53 PM #6
tig welding for dummies ? WHAT????????
Inferno Forge
Chris
06-25-2008, 01:58 PM #7
wow
Im with you guys on this one, I cant see what the target group of users would be. I like the "Aircraft Frames" in the list suggested uses
If a guy is building an aircraft that uses a 4130 fuselage etc, the trend has been going back to torch welding with the added complexity and steps needed to Tig the same part safely. And at 165 amps at its duty cycle I cant image much of a use repairing engine castings. So most of the time, a homebuilder commonly starts of with a set of tanks and a decent torch, needed for brazing, welding, hot forming, and aluminum work.....so what will a 165 amp basic TIG unit offer them over what they already have in the OA setup? A shop wanting to get into stainless exhaust repair will probably want a higher end unit like the Dynasty anyway. I dunno about the other markets, but I think they missed the Aviation market here. That and with all the liability...im supprized they would reccomend a machine or process like that, especially with recent trends.
Just my thoughts from a limited market
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
06-25-2008, 02:05 PM #8
Seems like kind of a slap in the face
I'm not late...
I'm just on Hawaiian Time
06-25-2008, 02:27 PM #9
- May 2005
- 600
the answer is clear, Miller has been reading it's forums and have come up with a solution to:
"i just bought a Dynasty 350, i'm a total noob at welding, never welded before, not arc, mig, tig, nor JB,. can you guys tell me how to use this machine?" and so on.
either that or the marketing and R & D departments have got the primo weed and are sharing it amongst themselvesLast edited by PUMPKINHEAD; 06-25-2008 at 02:30 PM.
06-25-2008, 02:33 PM #10
It's nothing more than the econotig with an inverter power supply and a different box.
Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
