Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 76
  1. #51
    Sep 2008
    Blacksburg Va.
    60
    Thanks Captian I will keep that in mind. Great weldind on the Turbo colector
    Kenny Compton
    Cuttin,Grindin, Weldin, nutten better
    KCRacecars@yahoo.com
  2. #52
    Here are some beads
    here are my beads
  3. #53
    Mt. Clemens, Michigan
    277
  4. #54
    Jan 2005
    Jasper AB Canada
    36
    Default First Pics, Hopefully!
    Just a repair I did this week on a JD 710 backhoe bucket arms.
    Settings:
    Root 93A dig 100% 1/8" 6010
    Hot pass 98A dig 100% 3/32" Arctec 223
    Cover pass 98A dig 100% 3/32" Arctec 223
    Dynasty 200dx 3ph 220
    All welds done in position. Uphand 45 deg.
    Any advice apreciated.
    A Failure To Plan On Your Part,
    Is Not An Emergency On My Part!
    When you build something Idiot Proof..
    Someone builds a better Idiot!
    Scott S.
    Jasper AB
    Canada
  5. #55
    Akron,Pa
    152
    Man for some reason I love the pics of the heavy equitment repairs you guy do. Do you or any one have any more?
    Quote Originally Posted by pcwelder View Post
    Settings:
  6. #56
    Jan 2005
    Jasper AB Canada
    36
    Not currently on the camera, but I can post some here later. Lots of repairs at my shop, when NASA wasn't hiring I think we got all the rocket scientists. Lucky us!!
    Scott S.
    Jasper AB
    Canada
  7. #57
    Langley BC Canada
    4,635
    Scott, nice looking welds. If you don't mind me saying so, don't put a 6010 root in next time, keep it all lo-hy, it means you often have to do more of an aggressive prep with the bevel as the root penetration with the lo-hy is not so good, but it is much more resistant to hydrogen embrittlement.
    For anyone wanting to see some more heavy equipment photos, I have a bit of my stuff here http://welderstephan.googlepages.com/home Its currently on a free hosting site, so if too many people look at it, it goes blank for a while I plan to transfer it over to a proper site this winter when I get ambitious enough to build a real website. I haven't updated the old one for quite a while now, as I planned to wait until I got the "real" one set up, but..... you can see how well that has gone so far
  8. #58
    turbo38t Guest
    Lookin at all u pics I wish I could go back and just relax in my chair welding adaptors on 10 yard pc1000 buckets......seemed like it was a day an adaptor.......why did you piece the blade together on that excavator blade? The owner didn't want to spend the money for a bent blade? Dave
    Quote Originally Posted by Coalsmoke View Post
  9. #59
    Jan 2005
    Jasper AB Canada
    36
    Thanks coalsmoke, I use 6010 for the root only because I seem to be able to control it better in out of position stuff. Then once there is some thermal mass i can lay in the 223 (7018) with more confidence. I run 1/8" 223 @ 103 Amps for all my flat and horizontal work, the slag is almost self lifting when the heat is in that 'sweet spot'.
    Thanks again will be posting more pics when available.
    Scott S.
    Jasper AB
    Canada
  10. #60
    Nov 2008
    Atl, Ga
    371
    There's some gorgeous pics in there. May I ask what rod you are using to weld the shanks on those excavator buckets?
