Page 1 of 8 123456 ... LastLast
Results 1 to 10 of 76
    Aug 2007
    Vancouver BC Canada
    605
    Default Lets see some beads
    We havent had any beads around here in a while. I'd love to see some decent Stainless welds- seeing as how thats where my troubles have been lately. Anyone care to share?
    Ive pasted 4 pics. Four different levels of competance. 4 pics, 4 minutes of experience....
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Jan 2007
    Alberta Red Deer
    373
    way too hot, turn down the amps. im guessing ur tigging these welds? amps at about 50 for this light of stuff and make sure u have good gas flow. ill try to get into the shop do do some for ya and take some pics but been pretty busy packing. (moving to australia)
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    Jan 2007
    Alberta Red Deer
    373
    hey were are u at in van? i have to spend a couple days in surrey before i go ill be there right around the 7th of july pm me if ur close and want some help.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    o/a torches
    Nov 2007
    Appleton Wisconsin
    419
    Default Stainless welds
    Here are a couple I have done. Nature of the business-I can't load more it would give the project away.
    Nov 2007
    Appleton Wisconsin
    419
    Default more
    more stainless, I had to crop some of the project out and resize so it made some pics a little fuzzy. These are from a "canned" accu-curve program in the Axcess machine.
    Aug 2004
    Thunder Bay, Ontario
    64
    here's a couple of some welds done using an Argon/Hydrogen blend. the hydrogen produces a reducing atmosphere that helps reduce the oxidation to pretty much zero. increases fluidity, faster travel speed, lower heat affected zone, etc.
    May 2008
    Mpls, MN
    464
    Here are a couple of my practice beads, I have only a been tig welding for about a month. The stainless is some 1/8 scrap with 308L filler I got from a machine shop and the aluminum is some 1/16 6061 with 5356 filler. The T-Fillet weld looks slightly "Sandy" but it is because of the weld I ran on the backside.
    -Dan
    Nov 2007
    Appleton Wisconsin
    419
    Default TIG welds
    Aluminum is a blast isn't it. Your welds are looking good. It has always amazed me how 1/2 way through a weld you have to back off a little or the puddle gets to large. I know it is the heat and I understand the thermal dynamics of the weld. It's just so cool, welding a awesome!
    Feb 2007
    now in Orlando!!!!
    557
    Not a bead, but some stainless on pipe....with O2 tank partially full, every thing turned out a ok.....Paul
    More Spark Today Please
