Results 1 to 3 of 3
    350
    Default Mig Pressure Setting
    hello guys.
    i never mig welded before with shielding gas, only flux cored, so i need some help for a friend.
    he is mig welding with .024 wire and using a 25/75 mixture. not sure what the mixture is.
    he is welding on automotive sheet metal and is running the pressure gauge at 7psi.
    does this sound correct ?
    thanks much.
    leonard...
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    2,641
    The Gauge should have CFH not PSI readings for the Flow.
    PSI side is for the tank pressure
    15-20 CFH
    350
    thanks..i will forward this to him.. thanks much..
    SyncrowaveŽ 200
