Results 11 to 13 of 13
    Vancouver BC Canada
    605
    Default Thank You!
    Best thing that happened in three days! I'll give your suggestions a try and see if I can get some better results..
    Anyboday want to trade Mondays??? Mine sucked BIGTIME
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Lake of the Ozarks MO
    3,447
    On stainless you only weld very short distances and then let it cool or it will sugar (turn black) if you let it get too hot.
    I welds more like steel. You might play with some steel for a bit as well.
    If you are used to aluminum tig it is hard to make yourself do those little stainless welds.
    It just sounds to me like you are simply letting it all get WAY WAY too hot.
    You may need to back purge as well.
    Possibly you may have gotten ahold of some funky material??
    To me stainless is a slow process...nothing you weld as fast as you can go.
    Different animal for sure.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Vancouver BC Canada
    605
    I did some more welding today. I turned up the gas, lower the heat, repointed the bit after every "dip' and moved as fast as i could. REsults were somewhat better but still hurting. My welds looked a bit shinier but still dark.
    not as much sugar. I dont understand why this is so dificult. You'd figure doing aluminum would be harder... I think too that the filler rod i was using may have been too large. 1/16th rod on .050" metal? Anyway the melting of the electrode in -DC was my on doing. too much amps and I dipped it more than once. I see that stainless is not as forgiving as Aluminum when the electrode gets contaminated.
    From todays self lessons, I managed to get some very small beads that looked sor of shiny. Haardly used any filler except when I blew out the seam..must keep practicing.. Thanks for your suggestions guys.. I took them all into account today and for the most part my results imporved. Still ugly as **** welds but better thna yestedays.
    Syncro200
    Spectrum 625
    O/A
    54" laminator
    little dog
