    Crete Illinois
    186
    Default Redecking car trailer
    Hello All I've seen plenty of people building trailers on here and was wondering if anyone had recommendations for gauge/thickness for diamond plate to redeck my car trailer? It's currently wood that seen better days ...I'll be reinforcing angle iron trailer frame with 2x2 tubing then laying out diamond plate for the new deck . I was thinking maybe 14 gauge thickness. Any suggestions would be appreciated
    Thanks Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Millermatic 180 w Spoolgun
    Miller Gold Seal 155
    Miller Elite welding helmet
    JD2 Tubing bender with Hydraulic conversion
    Evolution Raptor15" SteelDry Cut Saw
    Hypertherm Powermax 30
    Some really cool hammers BIG and small
    1,589
    It all depends how far the ribs are spaced. I built a car trailer using 14 ga dia plate with 3" channels running side to side spaced at 24". I had to add a 1/4" x 2 flat bar standing on end in between them running front to back under the driving area. This worked out o/k. If your going to jack up the car on the trailer make sure your on top of a rib. If weight is not an issue then 1/8 would be much stronger.
    Ocean City, Maryland
    951
    I might stay with wood if it were mine. probably Cheaper and will really hold up for years. Also not as slippery as metal floor. Just a thought, metal is nice but gotta paint it, wood you can put sealer on it every couple years.
    Just a thought
    Scott
    HMW [Heavy Metal welding]
    May 2008
    Belle Plaine Iowa
    233
    Im doing mine with wood. It no fun to go sliding off a wet metal trailer deck. Even humidity will make it treacherous.
