Results 1 to 3 of 3
    3
    Default MM210 drive rolls
    What is the proper drive roll set for .030 flux core? They list this wire on the chart inside the MM210 cover, but there is no listing for a .030 flux core drive roll set.
    Also, what is a good online sorce for Miller parts?
    Thank you,
    Joe in NH
    Sep 2002
    Clark County, NV
    2,696
    They do make special v-knurled rolls for driving FC wires, but I only use them on big wires, like in my LN-25. The .030 FC wire in your MM210 should work just fine with the stock smooth drive roll.
    May 2007
    539
    on my 210, I use the std rolls on .035 flux core, and it works fine.
    One thing, had the tension too tight at first, backed the tension off and it feeds like it should. Tighter is not always better.
    I have used brwelding, they deliver as promised.
