Results 11 to 18 of 18
Thread: the best one
    Noth Dakota
    505
    In my biased opinion there are no 120v welders "With good welding capacity". In my unbiased opinion there are 120v welders that serve a purpose.
    2,641
    Quote Originally Posted by StillBoostin View Post
    Don't go Lincoln it is not as nice as the MM140 or the HH140.
    James
    Can you elaborate?
    4,248
    I would second that as fairly accurate.
    Jan 2008
    haslet, TEXAS
    109
    thanks guy's for all the quik answers! I know there isn't a 120v welder with great capacity but i'm just a 13 year old so i don't plan on doing a whole lot of heavy structual grade material, just some around the hous projects and maybe a little texas art for my dads store.
    I know that most max's are an egageration but would the lincoln being qouted at 1/16 more(with flux core) than the hobart's capacity actualy weld more than the HH140?
    Also is the hobart rated with flux core or solid?
    And if I do come across something heavy couldn't i just bevel the edge or bothe edges and weld bothe sides?
    2,641
    Quote Originally Posted by 2tay530 View Post
    Yes,
    HH140 or the Lincoln
    Either one will serve you well
    2,641
    Don't think about it too much:
    at this size/ capacity machine the HH140 and the Lincolns are the same machine- different color
    Jan 2008
    haslet, TEXAS
    109
    thanks for the answer Brocoli1! I replied to your question on the discussion board. That makes me feel much beter that I can acomadate for the material thicknes!
    Jan 2008
    northern california
    318
    Default The weldpak will weld to 5/16" with multi pass
    Sorry for the delay in answering. I have welded up to 1/4" with the weldpak using flux core and 3 passes (beads). For a small job you could grind a V or notch between the two plates. I really wouldn't weld anything over 3/16" that would be subject to much stress though. I later upgraded to a MM175.
