    May 2008
    OCEANSIDE, CA
    123
    Default Noob with 140 autoset and spoolmate 100 wire question.
    Okay this is my first post and hopefully I won't get flamed because it's probably a stupid question, but here goes... I have 1/8" 6061 Aluminum that I've cut into practice coupons to try out the spoolmate I just bought and I was wondering if I have the correct wire. What would the correct wire be?
    Nevermind. got it figured out
    3,671
    Send us some pics when you are done...Bob
    May 2008
    San Diego
    180
    Default Wire
    Use 4043 for the best weld appearane.
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
    Mar 2008
    Baltimore, Maryland
    315
    I second 4043 wire. .030 will work. I will come out alot faster then the regular M10 gun. Do as much research as possible. Use 100% Argon for your shielding gas. You can not use 75%CO2 25% argon; it will not work so don't waste your time or materials. 10-15 degree angle and push not pull. It's pretty easy after you mess a couple up. The Settings inside the welder are pretty close too.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
    May 2008
    Austin Tx.
    101
    At my work, in an auto body collision repair shop, my assigned welder is a millermatic 210 with that spool gun option. we modified the welder(cart) to hold two bottles of gas. 100% argon and the standard mig weld mix, side by side.
    The machine is smart enough to determine which gun that the triger is being pulled on, but it is up to the operator to open the correct bottle.
    Yes I use the 4043 wire as well.
    And push, not pull the bead.
    On a plug weld on thin metal,
    You start the bead outside the hole and move inside the hole and work your way back out of the hole before letting off the trigger.
    Or.. at least that was the way I was taught.
    Randall
