Results 1 to 5 of 5
    598
    Default taking cover off dynasty
    would there be any problems doing this ? not that i am going to do it, but i like to see the internals of things. and "maybe" i will see a potential problem. and perhaps clean it out. i don't think i have any warranty left on it.
    Oct 2004
    Edmonton, Alberta
    6,763
    Which Dynasty is it
    if you indend to take the cover off, I could supply you some preventative maintanance pointers.
    Texas
    279
    Cruizer, I think Jess has a 200DX
    L*S
    Oct 2004
    Edmonton, Alberta
    6,763
    Quote Originally Posted by Leons2003 View Post
    L*S
    I get to work on lots of those as well
    The brass nuts on the backs of the output studs that hold the voltage feedback wires tend to loosen off, best to tighten them and use a locktite to hold them into place. (This will cause an erratic weld if left loose)
    The input strain relief on the primary going into the machine tends to over tighten the primary cable to such a degree that it breaks the cable. We've been replacing this with a metal sleeved version 3/4 x 3/4" rubber sleeved strain relief
    Right side lower center black (Hall device) tends to move around, we've been either opening the base and retightening it, or a quicker approach is to simply apply RTV to it and to the heat sink it is attached to.
    Other than that, lightly tap the 2 upper boards into the mother base board to make sure they are seated firmly.
    598
    thanx Leon
    yes, i have a dynasty 200dx..
    so, you say that i will not trip some kind of self destructive device inside ?
    output studs. those are where the working cables , - & +, connect to the front of the machine ?
    i will check the strain relief. does this happen on machines that are very mobil, or all machines ? my machine doesn't move around much.
    i will check the Hall device.
    i will check all connections.
    thanx a ton. anythink else ?
