Results 1 to 10 of 17
    Sep 2006
    Milton Ontario
    29
    Default Best tig torches for chassis work
    I am looking to buy a new tig torch for chassis work. I have been using a CS310 for years, since I could be welding 1/16" SS one minute and 1/4" aluminum the next. I have always found it to cumbersome for doing chassis work but just put up with it. After working on a rollcage all day today I have had enough. I'm not sure if I should go for the smallest watercooled or will an aircooled be adequate?
    May 2008
    Mpls, MN
    464
    My vote would be for a water cooled torch. I have used both and water cooled is smaller and cooler, generally more maneuverable (the cables/tubes are more flexible). Unless you need really small I would think a #20 like a Weldcraft WP-20 would fit the bill perfectly.
    -Dan
    Steve,
    My favorite for doing my chassis work is the Weldcraft WP 225. It is a 250Amp flex torch and has different heads that you can set up for different work that interchange right on the torch body. I use 4 main heads. The #9 70deg, #9 90deg, the #24 and the 1726 for heavy work like your 1/4". The 1724 and the 9 70deg are included with the torch purchase.
    Good luck!
    Andy
    Queens NY
    1,547
    is it water cooled?
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Sep 2006
    Milton Ontario
    29
    It would be nice if I could get away with air cooled, for the weight.
    Water cooled are as a rule, lighter than air cooled....
    compare the CS310 body at 3 oz
    vs. the CS300 (air cooled) body at 10 oz
    The WP-225 mentioned is water cooled:
    Weldcraft® WP-225 (formerly SF-225) TIG Torch Specifications
    Amperage: 225 DCSP maximum, 100% duty cycle
    Water-cooled body: 180º body with interchangeable heads
    Electrode capacity: .020" (.5mm) -- 5/32" (4.0mm) varies by head type
    Torch body weight: 4 oz. (113.4g)
    Torch length: varies by head type
    Handle diameter: 3/4" (19.0mm)
    Water flow: 1qt./min. (0.946 L/min.)
    Maximum pressure: 50 psi (3.448 BAR)
    The WP-20 is probably the most popular water cooled TIG torch but the 225 offers a lot of flexibility.
    Carmen Electrode (Arc-Zone.com)
    CarmenElectrode.com
    powered by... Arc-Zone.com (R) Inc.
    Nov 2007
    184
    One more vote for a flex neck/head water cooled.
    Sometimes it's really nice to be able to bend the head
    around where it needs to be.
    Dave P.
    There is a conversion kit from Weldcraft for your air cooled torch to use the interchangeable heads but you still only have a 150 amp system.
    Andy
    Queens NY
    1,547
    Andy,
    any chance you could post a few pics of that torch, and the heads? maybe with a piece of tubing for comparison?
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    The diameter of the torch is 3/4" sames as the the WP-20 and
    the body is 4 oz. The length will be determined by which head you attach. Here's some pics of some of the various heads:
    http://www.arc-zone.com/index.php?ma...h=13_18_42_342
    Hope that helps.
    CarmenElectrode.com
