Results 1 to 10 of 20
    Default Reciever hitch for lawn tractor
    I use my lawn tractor to move my utility trailer around my back yard as there is not enough room to manuver it with my truck. The problem was that the hitch on the tractor was very close to the ground so the tounge jack of the trailer had very little clearance. It also took a lot of jacking the trailer up and down to move it with the tractor and then hook up to the truck etc.
    I found the reciever tube on the road and used all scrap metal mostly 3" by 1/4" strap and one piece of 4" by 1/4" strap. The tie down rings have been laying around the shop for a while so I put them to work here.
    Now i just need to throw together a few useful accesories that I can attach with the new 2" reciever on the JD.
    Larry
    "I feel for the man who can only spell a word one way"......Mark Twain
    Lincoln AC225-S (OLD/Copper Wound)
    Lincoln Weldpac 100
    Miller Matic 180 (auto set)
    Miller Spool gun 100
    Miller Spectrum 375 Extreme
    Victor Super Range II
    Ocean City, Maryland
    951
    That looks cool, I think its probably built out of heavy enough material and nice paint job.
    Scott
    HMW [Heavy Metal welding]
    Apr 2008
    JACKSON, MS
    88
    Default good job
    nice lookin' job man. nothing like the convenience of a smaller vehicle to do smaller tasks with. i have a john deere gt 275 48" cut and it's wonderful for small jobs. i built a little shelf to go behind mine where i either keep a spray rig or a plastic bin for sticks and trash when i'm mowing (i'll get some pics and post them early next week). your tractor looks a little larger--which model is it?
    1 BEST 6 Y/O HELPER IN THE WORLD
    2 VICTOR O/A TORCHES
    LINCOLN SP 175 PLUS
    4 EACH 20 TON JACKS
    SEVERAL LESSER TON JACKS
    SEVERAL GRINDERS
    LOTS OF HAMMERS MISC SIZES
    BIG PILE OF MISC TOOLS
    CLASS A CDL'S
    C7500 FLAT BED
    4 TRAILERS
    HOME MADE GANTRY CRANE
    SOME GOOD COMMON SENSE (I THINK)
    TRACTOR WITH NEW HEAVY DUTY LIFT POLE -- FIND MY THREAD
    6 GOATS, 1 DOG, 1 DONKEY...
    ON AND ON AND ON...
    Raymore Missouri
    1,920
    Default another solution
    Larwyn,
    Good idea and good photos. This is my solution.
    http://www.youtube.com/watch?v=JbHMVneIS5g
    BTW, welcome to the site and thanks for sharing.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Jul 2004
    Jackson, MI
    46
    very nice work. I like the good alingment with your truck. I think I might borrow your idea. Thanks.
    Jan 2008
    Colorado
    673
    Thumbs up
    Nice job. Even if you had perfect beads, outside welds wouldn't look as nice. It looks really 'clean' without any welds showing.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Sep 2006
    South Central Kansas
    58
    Looks good, I put a hitch on the front of my lawn tractor for both moving around my trailers in my yard and also use the hitch when lifting the front of the little tractor with my hoist. Makes it very handy for working on the blades or under side of the tractor.
    Nov 2007
    184
    Looks like a little X300 lawn tractor.
    Dave P.
    Thanks for all the comments.
    Figured someone would mention that there are no welds showing. Believe me you would not want to see them......
    Yes it is a little John Deere X300 lawn tractor with a 42" mower deck. Not very big but more than enough for mowing my under half acre lot and big enough to act as an occasional trailer dolly on my relatively flat yard.
    Larry
    Lincoln Weldpac 100
    Jan 2008
    Colorado
    673
    Smile
    Quote Originally Posted by Larwyn View Post
    A man has got to know his limitations. FWIW: Try 7014, it's supposed to make pretty welds and isn't moisture sensitive like 7018; so it will keep for years. 6013 also makes nice welds and in that application would be plenty strong. OBTW: my stick welds suck.
