Results 11 to 20 of 28
    Northern CA
    90
    Quote Originally Posted by DSW View Post
    For me the top extensions are too short. Looks to be only 3-4" max. I actually put lumber on my racks and that's only 2-3 2x's stacked. Nit picking I know.
    Looks very nice BTW. Does it fit in an acceptable size box for UPS or FedEx shipping? I forget the max sizes they accept. You may be able to make the design a breakdown design if the horizontal bar could slide down over the vertical supports and get secured with a bolt. Just a thought for decreasing shipping costs and box costs. I would also think about powercoating the frame as suggested above.
    The height of the top is a bit of a compromise between looks and functionality. It still works good in my opinion but for just a work truck for a contractor, a little taller would probably be better.
    As far as shipping goes, it just fall under the 130" max (length+girth) for UPS. I wouldn't buy it If I lived across the country though; the shipping is not cheap. A short hop across states might be worth it if this is just what the customer is looking for.
    EDIT: I guess I should have done multi-quotes...
    Austin, TX
    621
    The rack itself may be too short. I crazily carry 20' pieces a lot on top of my rack and at this height the metal would probably whack the roof if I went over a bump. Even though it doesn't look as good, the top of my racks are ~ 7-8" above the roof.
    Also it might be nice to have a full cleat in the middle and some other tie down point at the base.
    Have you noticed any whistling?
    My rack (I didn't make it):
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    Jan 2008
    Colorado
    673
    "The rack mounts to the front stake pockets in the bed by a simple plate with a nut welded on the backside that sandwiches the edges of the stake pockets between it and the rack. It is surprisingly strong and means no drilling."
    I looked at the pics and missed this part.
    So, I said the bolt was too close to the pocket and would pull out if someone hit the brakes with the rack loaded heavily. If you sold one, some redneck would load 'er up. I also said "I'm just a hobby guy and don't like to judge the work of others, but you asked."
    So my critique was based on my inattention.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Northern CA
    90
    Quote Originally Posted by tasslehawf View Post
    with 20' sticks of steel there would definitely be a problem with this rack. I only built the front part that protects the cab, not the full rack like you have so tying things down is a bit different.
    More tie down points will definitely go in the revised design. Thanks for the advice.
    Oh and no whistling
    Northern CA
    90
    Quote Originally Posted by Craig in Denver View Post
    That was and still is a bit of a concern. I left enough room on the mounting brackets to drill a hole and mount through the bedrail at another point but this way was surprisingly strong.
    I agree with you completely though that some idiot would overload this thing and expect me to fix it
    Thanks for the advice Craig
    Austin, TX
    621
    Quote Originally Posted by dabeldesign View Post
    Oh and no whistling
    Yeah, I wasn't sure if your rack was just one or two. Just one it makes more sense.
    May 2008
    San Diego
    180
    You should put a weight limit on them if you're going to sell them. Think of liabilaty. I made some and the worked fine, but you never know what people will do. Insurance is the best policy.
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
    Vero Beach, fl.
    761
    Quote Originally Posted by lanceman73 View Post
    That is some great advice right there! Smart thinkin'
    Northern CA
    90
    I absolutely agree! I need to figure out what the weight limit should be exactly and maybe, if I really get into selling these, I can stamp the max weight into the rack.
    Thanks for all the advice and input guys! It's interesting to see other people's views and knowledge from around the nation (and maybe further) applied to my project.
    Feb 2008
    North of Phila. PA
    404
    Oh and about the "buffer" I still need to pick up some rubber matting. Any good sources for something like that besides McMaster-Carr or the obvious Home Depot?
    I looked for rubber material to bufer my rack that I am working on. After a bit of thinking on where I could get some medium sized pieces I remembered some PVC shower liner that I have left over from a job. Lowes and HD sell it by the foot as well as in sheets in the plumbing dept. If you know a tile guy, you might be able to grab some of his scraps cheap.
