    Raymore Missouri
    1,920
    Default What size spool for 180 mig
    What is the max size wire spool for the Miller 180 welder. I think it's 8". If so, what is the weight of the full spool. My Miller 150 will take 44lb spools and I like that.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    in .023 solid wire an 8" spool is 11 lbs. i suspect that will verry with flux core or even wire size, but 11 lbs is a place to start..
    3,948
    My welder will take the bigger 44# spools but i don't use them because sometime's i just tack weld, 5,000 or 6,000 of them and i don't want to wear out the drive sooner so i use the smaller spools. The bigger one are cheaper though....Bob
    Jan 2008
    328
    Default 11 # is the most I have seen on 8" spool
    Some of the fiber spools may look a bit bigger, but most only have 10# of wire on them. Of course the fiber spools weigh about 2 # empty.
    Northern California
    209
    Default Economy.
    The large rolls are quite economical unless they are left in an area where they may rust. If they get any rust at all on them, they are scrap. That's why I prefer the 2# and 10# rolls on my SP 175 plus Lincoln. It won't take anything larger than the 10# anyway.
    Bend Oregon
    62
    I have a Passport Plus and I think it uses the same size spool as the 180. Mine uses a 8" 10 lb. 0.030 mild steel spool.
    Miller Maxstar 150 STL
    Miller Millermatic Passport Plus
    Thermal Dynamics Dragun Plasma Cutter
    Protect your seccond ammendment rights! Join the NRA!
