Results 1 to 7 of 7
Thread: S.s Mig ?
    Aug 2006
    near rochester NY
    9,881
    Question S.s Mig ?
    if i want to MIG SS do i still back gas with strait argon, even if i MIG with try-mix ? or should i be back gassing with try-mix?
    looking to try a little MIG on SS and want to know what all i need for best results. i have strait argon, strait Co2, and an empty 80 tank. so i was planing on filling with try-mix for SS and started thinking about what would be best for my back gas?????
    so whats the best option ???
    thanks guys
    alabama
    718
    ONLY pure argon or nitrogen.or you will get poor results.
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    Apr 2006
    Palmdale CA USA
    230
    Default Tri Mix
    The best Gas to MIG Stainless is a Tri Mix 90% Helium 7.5% Argon 2.5% Co2
    For TIG Pure Argon
    I don't think nitrogen would work for either process.
    Dynasty 200DX With TEC Superflex 9 & 17 Torches,
    Hypertherm 30A Plasma
    Rincoln SP130T Mig
    Aug 2004
    Thunder Bay, Ontario
    64
    Just a little clarification....while the 'best' gas for welding stainless is a 90/7.5/2.5 blend, this is true for short arc only. for higher voltages and thicker materials, blends like 90%AR/8%CO2/2%O2, and for pulse welding, 66.1%AR/33%He/.9%CO2 work very well.
    As for Tig stainless, look into a Hydrogen blend of 2% for thinner material and 5% for heavier. This applies only to 300series stainless steels. The Hydrogen is a reducing gas that increases fluidity in the puddle, reduces oxides, increases heat input for faster travel speeds, and the appearance is beautiful. I will see if I can find my camera and post a pic or two of some of my tig welds using an Argon/Hydrogen Blend.
    As for purging...pure argon works pretty much the best.
    another option to purging is using a backing paste. The only problem with using something like Solar B flux, is cleaning it afterwards is a bit of a pain.
    Hope it helped.
    Mar 2007
    Deltaville, VA
    2,241
    For your mig (MM 135--Short Arc) tri-mix is the best gas for welding.
    100% Argon is the best gas for purging (back gassing).
    Aug 2006
    near rochester NY
    9,881
    Thumbs up
    thanks SundownIII & sparx.
    Aug 2004
    64
    I found an older picture on my computer of a tig weld done with 2% Hydrogen on 316 plate. notice the heat affected zone is pretty small compared to those of argon welds. I did a 'speed' test with an outside corner weld on 3/16 ss plate, no filler, 20 seconds of arc/travel time. The pure argon got me about 4" of travel, the 2% H2 blend got about 6-1/2" of travel, and the 5% H2 blend, I ran out of material (10" long coupons) so I figured I would get about 11 or 12" of travel with the 5% H2/Argon.
