Results 1 to 7 of 7
    May 2008
    13
    Default question for Andy
    hello from italy Andy,
    i`m going for chrome moly 4130N 1 5/8" .95 and .83 for roll cage on a rock crawler rig. using ER70S2 1/16 and 3/32 tung. around 90 110 amps. how should i set the pulser control on my dynasty 200 dx ? PPS PEAK t BKGND A ?
    or am i yhinking wrong?
    my best regards, fabio
    Mar 2008
    Anthem, Az
    31
    The settings I use on my Dynasty 200DX for tubing are:
    85-95 Peak Amps
    30% Background Amps
    60% at Peak
    100-150 PPS
    You can start with these on some practice pieces. When changing parameters, change only one at a time so you can see how a change in each parameter effects the bead or puddle.
    May 2008
    13
    thanks for your setting info
    fabio,
    Sorry I missed your question.. I was actually on a VACATION!!
    Anyway... The pulser settings that Shamrock gave you are pretty good and are usually modified by the users needs, beed look and travel speed.
    At the PPS that he gives, the bead will show real tight pulse lines. If you want to use the pulser more for a timer to add filler, your setting will have to be around .8 to 1.2 PPS and add filler when the pulse goes high and move the puddle when on the low side. I find that at 60% peak and 30% BKGD on .095 tubing, you may have to set your main amps a little higher. If you are using a foot control or other remote amp control, don't be affraid to st the main amps higher and fine tune by remote.
    Another biggie for me would be to use the ER80S-D2 filler. It will better match the strength and elongation % of the 4130.
    Good luck and have fun!
    Andy
    May 2008
    13
    thank you Andy and i hope that your vacation was great
    Vacation was great.... I can't remember the last week long vacation we took.
    Took the motorhome up to Mountain Wi to visit family.
    Hard to get back in the groove though
    A
    Jul 2007
    Carroll County, Maryland
    108
    I usually have to go back to work to rest from the vacation.
    The definition of courage. "It's when you know you're licked before you begin, but you begin anyway and you see it through to the end no matter what." From "To Kill a Mockingbird"
