Results 1 to 6 of 6
Thread: contamination
    May 2008
    13
    Default contamination
    is written that when you tig , in this case chrome moly, and you touch tung in the molten puddle ,or the filler rod goes out of the shilding gas( argon), or you don`t use a dedicate wheel when you grind the tung, or your pre and post flow is not apprppriate, contaminations occur. what consequence you are going to have in your weldings even if they show nice and well done?
    Jan 2007
    Alberta Red Deer
    373
    the structure of the weld under the surface most likely will be compromised. IE porosity or other faults.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    Dec 2005
    wisconsin
    830
    well many things could happen,
    touching a tungsten to the molten pool can cause a splinter of tungsten to remain in the weld pool, this creates a brittle spot for a fatigue crack. Oxidation can cause inclusions of many different materials, also leading to fatigue cracks. Remember, 4130 ( if thats what your using ) is more sensitive to fatigue then mild steel. So to answer your question, the consequence is joint failure...that simple. Its up to you to decide if its ok if the joint fails.
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Jan 2007
    Alberta Red Deer
    373
    yeah what Aerometalworker said is all true was in a hurry and had no time to write it all out.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    o/a torches
    Nov 2007
    184
    Aerometalworker also left out the almost instant consequence of a
    tungsten touch..................
    violent cursing followed by the urge to beat something, usually
    the side of your own head for being %&#@ dumb!
    Dave P.
    May 2008
    13
    thanks a lot to everybody
