Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    May 2006
    Kansas City Missouri
    84
    Default Welding heavy plate
    Is the weave welding technique still used on heavy plate or is it all stringer work to fill the gap..
    Browns Valley, California
    1,713
    How heavy? What process?
    If it's thicker than my MIG welder is rated for, I'll do multi-pass. That's stringers.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    May 2006
    84
    Your right sorry about that. Regarding 1/2 to 1" plate work. Years ago I was strictly doing arc welding on plate, but don't know what process is used know. I'm told arc welding is just about dead, by the welding store sales reps.
    Mar 2008
    marsden,sk
    101
    imo stick welding will never die, way to flexible and adaptable.ive had the best luck with stringers on heavy plate(MIG or stick)
    07 f350 duallie w/deck
    07 tb302d
    2011 big blue pro 300 cat
    victor torch
    matthey beveler
    assorted hand tools
    4,364
    Depends on the position and joint design. I am not sure how much luck has to do with the weld deposit but quality welds are done with both techniques, weaves are used in groove welds except horizontal and vertical fillets.
    Alberta Red Deer
    373
    not true a weave can be use in all positions but it all comes down to ur hand skills. all processes can be used and a weave can be used with all but tig welding is better off with stringers but one can put in a sound and correct weave weld.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    Sep 2006
    Abilene, Texas
    639
    Quote Originally Posted by gearhead View Post
    I assume the experts you refer to mean stick welding since the term "arc welding" can be applied to various forms of electric welding processes. I wonder what they recommend for on-site (out of the controlled confines of a shop) welding on heavy equipment, farm equipment, fences, gates, drilling rigs, trucks, trailers, structures, signs, etc?
    Jim
    Queens NY
    1,547
    you can't deny the magic of FLUX!!! I think stick welding will be with us for may years to come. I wish i knew how to do it!!
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Apr 2004
    Moneta, VA
    108
    I've worked construction (pipe welding) for many years, I'll be one of the many that'll tell you stick welding isn't dead or any where near it! We still use it on pipe welds in nuclear plants. Stringers or weaves, it's up to the welder as to which they are more comfortable with. I like weaves myself as you can put down a lot more meat with each pass.
    Chris
    393
    WOW a sales rep said that. The three major processes that are being used are all ARC WELDING PROCESSES..(GMAW,SMAW,and GTAW) thats what I mean when I say the welding world is going to **** in a hand basket .And a good example of why ''formal training" is needed.
    To respond to what you asked..Heavy plate can be welded with a weave technique or stringers can be used. And it all depends on the position of the plate and the process as well as the rods.
    "Arc welding is just about DEAD" ask him whats replacing it.
