Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Default Miller Welding Cart
    I augmented the standard cart which came with my MM180 to also accommodate my new Spectrum 375 Extreme. It is basically a "side frame" with seperate cable hangars for the welder and the plasma cutter and a shelf of sorts for the plasma cutter. This is just a temporary measure to bring some sanity to my small shop until I have time to build a proper cart for these two excellent machines.
    Larry
    "I feel for the man who can only spell a word one way"......Mark Twain
    Lincoln AC225-S (OLD/Copper Wound)
    Lincoln Weldpac 100
    Miller Matic 180 (auto set)
    Miller Spool gun 100
    Miller Spectrum 375 Extreme
    Victor Super Range II
    May 2008
    Austin Tx.
    101
    Thumbs up
    That is cool.
    How do you like the mm180?
    Randall
    Mar 2008
    Baltimore, Maryland
    315
    Quote Originally Posted by fendermender View Post
    That is cool.
    Randall
    Nice mod to the welding cart. How is the MM180 w/ auto set. Came out a month after I bought mine.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
    Thanks. I could not be happier with the MM 180.
    I really did not expect to use the auto set feature all that much. But in practice it is much quicker than refering to a chart or relying on memory for speed and voltage settings. I like it. So far I have had no regrets about my choice of welder or plasma cutter, they are both impresive machines.
    Larry
    Lincoln Weldpac 100
    Alberta Red Deer
    373
    nice little cart looks like it will serve you well
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    Thumbs up nice mod.
    great little cart addition. looks like the shelf is small enough to still alow the door on the MM180 to be opened for wire replacement.
    thats a lot of function in a small space with that cart combo, congrats on getting some great equipment.
    Feb 2008
    Milwaukee WI
    57
    Very Nice, also like the grate over the garbage can
    Millermatic 210
    Thanks. Yes the door will raise fully on the 180 with the plasma cutter in place. Also if you remove the plasma cutter there is a gap to allow clearance to use the handle of the 180 to lift it off of the cart. I will need to add some bracing from side to side on the cart and put some larger wheels on it before I am satisfied with the result.
    Larry
    Lincoln Weldpac 100
    Quote Originally Posted by MilwaukeeMike View Post
    Glad you like it. That pic got in there by accident but the grate over the garbage can makes a decent cutting table for the plasma cutter and prevents a lot of sweeping up....
    Larry
    Lincoln Weldpac 100
    Braced it side to side, installed 3" casters and 8" wheels. It is solid and rolls 10 times better. Now I'm not sure how temporary this set up is....
    Larry
    Lincoln Weldpac 100
