Results 1 to 10 of 10
    Nov 2007
    Onalaska, WI
    149
    Default Anybody have a need for this?
    http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=008
    I have one like this and It runs my mm175 without even breaking a sweat.
    4,461
    I didn't look it thru completely but Mr handyman there has fooled with the grounding by changing the recept on that unit, buyer beware.
    looks like a nice unit, i could use one of them but i suspect it would end up well out of my $$ range. right now i use a 5,500 for backup power. it gets the job done but dont think it would run my welder's.
    2,936
    Yeah, why not just make a Pig Tail??
    Browns Valley, California
    1,713
    A 13KW rig should run your whole house without breaking a sweat!
    They come with a 4-wire plug because the ground and neutral are isolated in the newer generators. If he swapped out the 4-wire for a 3-wire, I wonder which leads he hooked up to the receptacle.
    Depending on which way he wired it, and what load he fed with it, there's a possibility of damage.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Sep 2007
    Bosque Farms, NM
    10
    No big deal. If he put the ground wire (green) on the groung lug (green) and capped the neutral it will work fine. If your equipment is 3 wire why screw with a pigtail that can get lost or left behind. Do it right. If you don't know how, hire an electrician.
    Feb 2006
    Northern CA, Shasta CO.
    157
    Quote Originally Posted by holsters View Post
    Yes, it would very likely work, just may not be safe. If you were running a single piece of 230 volt equipement that would be true and safe. If you were running a dryer that wouldn't necessarily be safe. Even if the dryer were wired for three wires, still not safe. Electric range, not safe. Feeding multiple 120 volt circuits, not safe. So it really does matter what is being done.
    Question
    Whos to say that the seller is not a licenced electrician or power worker?
    May 2008
    San Diego
    180
    Default Generator
    Sh@t!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
    Sep 2007
    Bosque Farms, NM
    10
    Quote Originally Posted by Sandy View Post
    1) Remember that a generator does not have an "earth ground". The "ground" and the neutral ARE THE SAME. Unless you drive a ground rod and connect the neutral there IS NO GROUND. If you think that because you have a 3 wire 120v receptical on your generator and a three three prong plug on your grinder your grinder is safely grounded, you're wrong.
    2) If your 230v dryer is designed for three wire, why wouldn't it be safe???
    ...at least as safe as it could be given that a generator HAS NO EARTH GROUND.
    3) Before you ask, yes, I've been a licensed journeyman commercial and industrial electrician since 1982.
