Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 81 to 90 of 98
  1. #81
    Jun 2007
    arizona
    105
    Default Hi Weldress
    "Windswept" is very cool - how long did it take you to complete? How is she attached to the granite? Cat
  2. #82
    Jun 2007
    San Diego CA
    32
    Default Female Welders Rule
    I Work For One Of San Diego Oldest Family Ran Iron Shops
    It Is A Women Owned Shop And We Have Two Welders In The Shop And They Out Weld The Guys All The Time
    I Work Out In The Feld Puting Up Stairs And Iron We Work With Other Trads Like The Dekers And They Have A Women On There Crew
    There Is A Women That I Have Seen In The Rod Patch " Yes A Rod Buster " We Have A Lot Of Rebar Going On Out Here
    There Are Women In All The Trades In San Diego I Have Seen This First Hand And They Do Work
    But There Is A Big Problem With Women Welders You Can't Yell At Them Like We Do The Guys
    All Women That Weld Or Do What We Do "got All My Respect"
  3. #83
    Nov 2005
    23
    Default how is she attached
    Quote Originally Posted by cat View Post
    I built the whole piece, basically HUNG it on a long piece of 3'' seamless pipe running fom her neck to 12' below her heel.
    I bent the pipe to conform to her chest, hips and the main standing leg(or trunk!) Then I built a fine wire body to guide me and added the corten to that.
    So she is complete in every detail..fingers and toes included, even though you don't see them clearly because of the foliage I added later.
    When the piece was virtually finished except for the standing foot,I has the granite drilled and inserted the 12' of pipe extending from her foot,and used powerful expanding grout to hold her.
    I then built the foot, and then the roots, and used tapcons to secure the roots to the rock.
    So really her 'taproot' and the roots that extend over the rock are what holds the piece together.
    Obviously it was picked up with crane straps under the granite.
    The piece travelled 400 miles on the bed of the crane truck to be installed, an although she swayed, nothing was weakened in transport. (I was more worried about her height under the overpasses! I kept ducking in the truck cab as if that would have helped)
    This is a wonderful piece in all seasons...in winter she is amazing..looks just like a bent pine covered with snow...then in spring she emerges.
  4. #84
    Jun 2007
    arizona
    105
    Default Hi Weldress
    I would have done the ducking for overpasses, too! And I would have been looking out the back window all the time. Were you able to relax at all on the trip? I once made a large lizard as part of an address sign that had to be attached to a rock. I welded spikes onto the lizard, drilled the rock and epoxied. Worked great. It was a much, much, much smaller piece. Yours is a wonderful piece. Cat
  5. #85
    Oahu, Hawaii
    2,469
    Weldress...you - are - phenominal.
    Cat, you HAVE to have pics of your lizard, right?
    I'm not late...
    I'm just on Hawaiian Time
  6. #86
    Jun 2007
    arizona
    105
    Default bert
    yep, here's a pic. he's not very elaborate but he worked for this desert location. Cat
  7. #87
    Wartburg,Tn
    575
    those are aewsome
    Inferno Forge
    Chris
  8. #88
    Oahu, Hawaii
    2,469
    Default cat
    ok...that is **** COOL
    I'm not late...
  9. #89
    Nov 2007
    Appleton WI
    59
    Truly amazing. You are quite talented!
  10. #90
    that ox thing is friggen cool ... i wonder if it will end up weighing the same as the real guy did... lot of metal goin on!
    that corten steel is sweet lookin.. is it relatively expensive compared to regular mildsteel?
