Results 1 to 5 of 5
Thread: Shifter Kart
    Jan 2010
    Calgary, Alberta
    197
    Default Shifter Kart
    Hi Guys,
    Havent been on here for a while so i'll post the pics of my latest project. A 140cc shifter kart. I started with 1 1/4" Steel Tubing with .120 wall thickness and bent it up using a cheap Princess Auto bender (actually designed for pipe) but i used a grinder on the die and it worked allright after filling the tubing with sand.
    After bending the main rails, i filled in, using rough measurements off a professional frame but most of it is my own design including the whole front end. its basically finished now except for a few finishing touches yet to do such as to mount the plastic sides properly and hook up the brakes.
    Just a few pics to show it... i have more which i might post later if you are interested.
    northern NJ
    1,897
    Cool looking kart. More pics are always good.
    MM250
    RCCS-14
    Jan 2010
    Calgary, Alberta
    197
    Thanks MMW!! I'll post some more pics of it tomorrow sometime.
    Smile Shifter kart
    cool kart...
    Oct 2011
    Illinois
    58
    I dig it. Simple, but pretty sweet lookin.
    Any speed checks on it yet?
    Miller Mig 140 Autoset (2010)
    Miller Syncrowave 250 (1996)
    I have a lot to learn.
    -Joe
