Results 1 to 10 of 10
    PA
    288
    Default Titanium sculpture
    Here is a 6Al-4V titanium sculpture I recently finished. The top is 24" in diameter and is attached to the base with a 1 1/4" X 7 bolt so it can be taken apart for moving. The only non-titanium parts are the three 1/2" x 13 stainless bolts holding the top to the base.
    I could have welded the two pieces together but decided not to in case I wanted to use the base for another project in the future.
    The hardest part was welding the inside joints. Had to leave a couple of openings in the top so I could reach inside to complete the welds. Then I filled in the holes. Luckily I could fit my tig torch thru the pieces to get inside.
    Used four 336 cu ft tanks of argon to finish this project as I set post-flow time to 20 seconds for each weld.
    Base appears to be some aviation related part as I see heat discoloration.
    Piece weighs 80 lbs so I could probably get a good price for scrap value alone.
    Probably have more money in tig wire than the scrap pieces.
    Apr 2006
    San Diego
    375
    Thumbs up
    Cool piece, Burnt Hands.
    Looks like fun.
    Did you find those top pieces as drop/scrap material?
    I'm not an airplane guy, but it would be interesting to know what that cast bell-housing was for.
    Thanks for sharing.
    MIRABEL , QUEBEC , CANADA
    50
    Hi Guys
    Nice Sculpture , The Cast Bell Housing Is The Center Of The Brake Assembly That Holds The Multi Disk Pads And The Rotor On The Main Landing Gear Of Big Aircraft.
    I Am Working For Air Canada
    Bobby
    FABRICATION-CRÉATION K ZEN
    MILLERMATIC 210
    SPOOLMATE 3035
    SYNCROWAVE 200
    HYPERTHERM 360
    Apr 2006
    San Diego
    375
    Quote Originally Posted by k zen View Post
    Hi Guys
    Bobby
    Thanks Bobby. Those must be some serious brakes. What are they making the rotors and pads out of these days?
    Columbia SC
    165
    Nice job, thanks for sharing..
    Jim
    Thumbs up neat
    verry cool.
    where did you get all the pices ??
    Mar 2008
    Baltimore, Maryland
    315
    verry cool.
    They call that SALT. LOL
    That is one cool sculpture. How much does it weight?
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
    PA
    288
    Default Ti sculpture info
    Hello all,
    I had collected these drops and scraps over the years from sellers on ebay and a local scrap yard whose owner has sadly ( for me, but happily for him) retired.
    They sat collecting dust and crying out for a use until I saw a photo of a stainless steel globe sculpture. It had round bars for the latitude and longitude lines and the countries were cut out of plate and welded to the framework.
    Finally had a design but one problem was figuring out a way to assemble the pieces into a hollow shell.
    The answer came when I went to a friends house for a cook-out and saw he was using a Weber round charcoal grill.
    So I bought the 22" model and used the base as a form to hold the scraps while I welded them together. Made 2 hemispheres then joined them together.
    Top weighs 52 lbs and the bolt and base weigh 28 for total of 80 lbs.
    Took about 75 hours over a 5 week period to complete.
    Bobby, thank you for letting me know what the base is from. This was a mystery to me.
    Here is a smaller titanium sculpture I'm sure everyone will recognize. The base plate is 6 7/8" diam x 1/4" to give you a sense of size. The fun part was looking on the internet for information on the dimensions of the actual place so I could make my sculpture proportional.
    Thanks for the nice comments.
    Thumbs up
    cool, nice lil model.
    Jan 2008
    Colorado
    673
    Exclamation
    Weber Grill!! I wondered how you got that thing so round.
    RETIRED desk jockey.
    Miller Syncrowave 250.
