Results 1 to 10 of 13
    9
    Default New guy tig welding 3/16'' plate
    Hi I just bought a syncrowave 200 to use on frame up rebuild of a 53 Ford truck. This is my first tig machine. I have stick and mig and gas welded alot, but this is first tig. My problem is I can lay a nice looking bead but I do not seem to get good penatration. I am using 185 amps with 3/32 filler rod. Any help would be great! Thanks
    Apr 2006
    Central NJ
    73
    Default Linger longer
    Linger longer (slow down) and watch the puddle not the filler. Heat, puddle, dip, move. That ougth to do it.
    Queens NY
    1,547
    Frunkis!!!!!!!!!!!!!!!!!!!!!!!
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Jan 2008
    Colorado
    673
    Lightbulb
    Joint type? A 3/16" butt needs a light bevel and/or a root gap. I'd think 1/8" filler would be more suited or lotsa dabs. Don't add filler til the keyhole shows up or the weld will just pile up on top.
    Laiky: what's 'frunkis' stand for?
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Queens NY
    1,547
    Quote Originally Posted by Craig in Denver View Post
    I want to see if PJinNJ knows!
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    Jan 2008
    Colorado
    673
    Thumbs up
    Quote Originally Posted by Laiky View Post
    I kin live with that. Add thread to subscriptions.
    Lake of the Ozarks MO
    3,530
    Quote Originally Posted by IH POWER View Post
    Well....You don't say what the material is?
    But...as with about anything either slow down untill it penetrates or go turn up the heat!!!
    Pretty ain't worth a crap if it's weak (as you already know)
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Fraser Valley, BC
    593
    Exactly, focus on making sound welds, then make them beautiful, and if in doubt take it to someone who you KNOW can do the job.
    Our school rail car required a clutch and chain gaurd to pass tech, so our teacher asked me to look at it. I told him I couldn't do it because I didn't have access to the proper forming tools, and he originally wanted it made out of aluminum. He ended up taking it to a local shop, not the one he regularly goes to due to time constraints. Upon initial glance it looked like they had done a beautiful job, it was made of lighter gauge stainless, with some very nice LOOKING welds. Well after two passes down the 1320 one of the mounting brackets broke, of a full 1.5 inches of weld, there was about an 1/8 of an inch of actual penetration in to the one piece. Luckily it had two mounting points and did not cause any damage to people around it or the car.
    Sorry if this is a little long winded, just wanted to share an example of what can go wrong. I fully support people trying to do there own work, but as Dirty Harry once said, "you got to know you limitations." So good luck, with some help and practice I you will get it.
    Oh, and make sure to post pictures too.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    9
    Default Slowing down helped alot
    Thanks for the replies, slowing down helped alot. I also think I was holding torch down at too much of angle from work. Thanks again
    Apr 2006
    Central NJ
    73
    Default Well, I've wracked my brain LAIKY
    BUT I have no idea what the term "Frunkis" means. Please enlighten me as it sounds like a term I'll need to know and/or be able to have some fun with.
