Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Mar 2008
    Baltimore, Maryland
    315
    Quote Originally Posted by Iron Head View Post
    For a 2-inch weld on MS or SS, I won’t twist the top on a gas bottle.
    Thats funny. I bought all three( Tri-Mix, 75%-25%, and Argon) so I would never have this problem. I recc tri-mix. Get a 20cf bottle. You might need it sooner then you think.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
    Aug 2006
    near rochester NY
    9,881
    keep in mind without the proper gas and wire you may get hold but will not get weather proof. if you want to keep it rust free you need to do it right. or paint after to rust proof.
    Scottsdale, AZ
    173
    Quote Originally Posted by fun4now View Post
    LOL thanks James, but rusting out is the least of my worries.
    I live in a desert
    I have got 2 fixed wheels on my SS BBQ and they roll in the wrong direction, gonna cut them off and rotate them 90 degrees...
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
  4. #14
    Jan 2008
    Colorado
    673
    Talking
    Quote Originally Posted by SavageSunJeep View Post
    I live in a desert.
    You live in a desert, it's a BBQ. Cut 'em, rotate 'em, weld 'em. Your buddies are jeepers, if they notice, give 'em a beer. If they're golfers, they don't know what a weld is.
    RETIRED desk jockey.
    Miller Syncrowave 250.
  5. #15
    Aug 2006
    near rochester NY
    9,881
    LOL great thinking.
    if rust is not a problem just hit them with steel solid wire and C-25 and they will hold fine.
  6. #16
    Nov 2007
    Appleton WI
    59
    for that little bit, give the C25 a shot. I've used it with good results, but I was just welding stainless onto a mild steel bearing surface to be machined down. I prefer the tri-mix, but for a small weld, will not go through the B.S. of switching the tank. Also if you're worried about spatter protect the surrounding metal well. I get alot of spatter no matter what I do. I could use some advice on that if anyone has any. It drives my machinists crazy.
  7. #17
    Apr 2006
    San Diego
    375
    I get alot of spatter no matter what I do. I could use some advice on that if anyone has any. It drives my machinists crazy.[/QUOTE]
    Anti-spatter spray?
    SavageSunJeep, get 'er done with what you got and post a pic.
    Forget about welding, can you just bolt it on?
  8. #18
    Scottsdale, AZ
    173
    LOL, good reading here on Sun morn. All my friends are Jeepers no golfers for sure.
    Splatter, sometimes I get it, sometimes I don't, cannot say for sure why. But for aboout $25 bucks or so I can fix your splatter problems forever.
    1) Harbor Fright angle grinder w/60 grit flap sander wheel
    2) Harbor Fright angle grinder w/steel wire wheel
    Total cost about $25, my problem solved, LOL.
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
