Results 1 to 10 of 18
    Scottsdale, AZ
    173
    Default MIG welding stainless
    Can I do MIG on SS. I have a very small project with not more than a couple of inches of bead and it would be SS to SS about 1/16th?
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
    Rosetown, SK.
    514
    Sure can. Use the mix gas & take a scrap piece if aailable to dial in your settings.We have done this many times.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    Scottsdale, AZ
    173
    OK, I am running C25 all the time, thanks, appreciate the answer...
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    May 2008
    Camillus, NY
    59
    When I weld stainless steel, I use a tri-gas mix, 90% helium / 7.5% argon / 2.5% co2, and stainless steel mig wire. While I have tried to weld stainless steel with ER70S-6 mig wire and 75% argon / 25% co2, I never had good results.
    Jack
    Auckland, New Zealand
    26
    All the stainless I've migged, whether with fluxcore or solid wire, has been done with pure argon. Results have been pretty good, if you don't mind a little splatter.
    Scottsdale, AZ
    173
    I think I will try it with what I have, can't justify the cots to buy all the other stuff for for this small and personal job...just trying to turn the fixed roller wheels (2) on one end of my BBQ so I can slide it out of its hole in the outside counter.
    Before I had the counter built it was not big deal, but now it is.
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    argon 2 - 5% CO2
    here is a link with good info on ss welding
    http://www.weldreality.com/stainlesswelddata.htm
    3,657
    Quote Originally Posted by SavageSunJeep View Post
    I use 75/25 for my ss projects, its not textbook but i am not building rocket ships....Bob
    May 2008
    San Diego
    180
    tig is 100% argon. Tri-Mix only for mig. Sorry, that guy that recommends c25. I've done plenty with argon using tig.
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
    SMAW will never die, i agree. Like the vacuum tube, it has it's uses. Although there are easier and more efficient methods that are improved and accepted as industry standard.
