I've found a 80 gallon tank locally. All I have to do now is fab up the mount for the compressor and motor and plumb it all up. The new motor should be here Monday, so hopefully I'll have it running next week. I know full well the dangers of air tanks, a neighbor of mine lost one of his legs from the knee down from a failure. Unfortunately he just happend to be walking by when it failed, yes it was a factory made tank. I'd never seen anyone build their own tank, that's why I asked here. The ends were something I was not sure of, hence the original post. There are people on here with far more experience than I have, or will ever have. There was no intention on my part to cobble something out of scrap. I am very capable of building it and doing a good job at it. I have a street/strip 69 Dart that runs low 7.20s at 95 mph in the 1/8 mile that I did all of the fab work on, so I trust my work. If I was not confident in my skills i would never even consider tackling such a job. Thanks to all of you that offered useful information.
Results 31 to 40 of 57
Thread: Anyone Ever Built an Air Tank?
05-13-2008, 05:18 PM #31
- Oct 2007
- W. KY
- 28
05-13-2008, 07:23 PM #32
- Dec 2007
- National City CA
- 1,086
Justin
Well said. And I'm not here to tell anyone what they should do either. Just pass along my experience and hope I help someone out.
If I had a nickel for every time someone told me I can't do something or I should leave it to a "professional" I'd have enough money to pay someone else to do it.
Things that I've done that most would not attempt or should not attempt.
(Keep in mind I'm talking about the general public, not people that post here)
rebuilt my first truck engine at 18 rebuilt my motorcycle engine at 20, i was already reloading ammo for a few guns at the time too. Rebuilt the diff in my jeep at 25, Learned how and did anodizing in my garage for four years for real paying customers, Rebuilt a few rifles i.e. stocks and barrels including setting the head space. And just in general fixed what was broke improved what needed improving Fabed, welded, and machined anything i needed all with little help from anyone.
I'm not boasting what I'm saying is if you are skilled and fully understand all the intricacies involved with a project then by all means have at it.
But do the research first and find out if there is something you're missing.
you'll be a better person for it and keep all your fingers too.
KerryMiller Syncrowave 200 W/Radiator 1A & water cooled torch
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Auto shades are for rookies
www.KLStottlemyer.com
05-13-2008, 07:54 PM #33
Tanks alot!
Listen, I've made my own 30 gal. tanks out of 3 11 gal. tanks. I agree that the chinese products are inferrior. To buy a tank though, is almost unaffordable. I was quoted $1500.00 per tank for what I made for about $300.
Thanks,
LanceMillermatic 210
Syncrowave 200
Spectrum 625 X-treme
Hobart Champion 16 W/
Miller 8VS Suitcase
Miller 3035 Spool Gun
Tons of Tools
Microwave
Laptop and Printer
Speakers in the Back for all to hear Sirius Radio!
05-13-2008, 09:32 PM #34
As far as I'm concerned the ASME cert. tags on most compreors are for liability purposes. I'd trust some of the farmer welds my dad makes before some of those chinese tanks.
At work some pressure vesseles don't even require ultra sound or X-ray testing and they hold as much as 2,500psi. However, They are engineared with about as much overkill as a WW2 Tiger tank.
I think the highest any of ou'r vessels get to is usualy around 4,500psi.
Here's a small one:
http://i162.photobucket.com/albums/t...Picture063.jpg
05-14-2008, 07:31 AM #35
- Oct 2007
- W. KY
- 28
anti-GMAW, I think the tank in you're photo would hold enough air for me
. It would wear my compressor out filling it though
05-14-2008, 04:15 PM #36
- Aug 2007
- 97
I certainly agree. Furthermore, when you do buy your tank, make sure that it is marked with an "ASME" tag. I have an 80 gallon vertical air compressor with an ASME tank and I wouldn't want to be anywhere near it if it ever blows. An ASME certification is worth more than mere talk. It signifies that the tank was built and tested to a known specificaton and that it is safe for the use intended.
My tank is abut 15 years old and it was made in USA.
Assuming an operating pressure of 150 psi, that's going to amount to a lot of pressure on each square foot.
It's more than merely being able to fabricate and weld the tank. It's the material you would use and the necessary hydrostatic testing after it's "done".
Uh-uh. That's not a job I'd tackle. There are certified tanks available from places like MCS and Grainger. That would be my course of action.
Gutless in Sacramento.
05-14-2008, 04:21 PM #37
big used replacement tank on ebay
check out ebay item number 130220533358
now that's an air tank
1 BEST 6 Y/O HELPER IN THE WORLD
2 VICTOR O/A TORCHES
LINCOLN SP 175 PLUS
4 EACH 20 TON JACKS
SEVERAL LESSER TON JACKS
SEVERAL GRINDERS
LOTS OF HAMMERS MISC SIZES
BIG PILE OF MISC TOOLS
CLASS A CDL'S
C7500 FLAT BED
4 TRAILERS
HOME MADE GANTRY CRANE
SOME GOOD COMMON SENSE (I THINK
TRACTOR WITH NEW HEAVY DUTY LIFT POLE -- FIND MY THREAD
6 GOATS, 1 DOG, 1 DONKEY...
ON AND ON AND ON...
05-14-2008, 09:18 PM #38
- Dec 2007
- National City CA
- 1,086
05-15-2008, 12:18 AM #39
Has anyone used propane cylinders as a cheap alternative to buying airtanks? for example you could get a 100lb propane cylinder and rig it for an extra air resevoir on your trailer or in your shop or something?? i've always thought of this and was told there was a safety factor of 3 or something built into the tanks.. not quite sure but a full cylinder yeilds 100 psi abouts last time i checked. What do you guys think?
MillerMatic 175
Cutting torch
Arc Air
Air compressor
Home built Gas air compressor
Makita Grinders
Mazda Pickup
Enough tools to start a bussiness but no money to do it with!
Current Build List
Truck mounted Welding Skid
Welding cable spools (Shell Ryn design)
Saving For
Vantage 400
Dynasty 300
Suitcase Extreme 12VS
05-15-2008, 10:39 AM #40
An 80 gallon air tank holds 80 gallon at zero psig , at 150 psi that 80 gallon tank in really holding the equivent of 896 gallons of air at atomospheric pressure, because of the density of the compressed air. If you use the formula to figure density, this explains why a 220 cuft gas cylinder, is small enough to carry, as a cubic foot of air is the air volume in 3' x 3' x 3' box at atomospheric pressure. As the pressure goes up the stored air is actually engergy, trying to uncompress itself.
cylinder or tank pressure + 14.7 / 14.7 = density factor
using the 80 gal tank at 150psi
150psi +14.7 = 164.7 / 14.7 = 11.2 density factor
80 gal x 11.2 = 896 gallons
example a 220 cuft oxygen cylinder at 2200 psi
2200 + 14.7 = 2214.7 / 14.7 = 150.6 density factor
220 cuft / 150.6 = 1.4 cuft the actual capacity of the cylinder at atomospheric pressure.
Jack
