Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 57
    Feb 2006
    Sacramento CA
    80
    I don't understand this line of thought as SOME ONE makes the tanks?
    Why can't Iron head or any one else that is qualified to do so make their own tank?
    Check the requirements necessary for a high pres. welding cert.
    2,927
    Quote Originally Posted by KEENAVV View Post
    As long as the person fabricating the Tank has the certs, what would be the problem?
    Queens NY
    1,547
    i think the problem is that the people who make the tanks, make hundreds and thousands of them. they have experience, empirical testing and certs. To make just one, you don't get any of that. I'd buy it so you can get the experience and quality of the above mentioned. Same reason some one who isn't an experienced welder shouldn't be doing critical work, and should pay a qualified person to do so, instead of suffering the learning curve for one job.
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Jun 2004
    nj
    204
    It isn't just the weld job itself... It is the design process, material verification, NDE On the finished product, and about 50 other things. The risk is much greater than the (possibly nonexistant) cost saving. The risk may not show for several years.
    For examlpe, a minor design issue led to some failures: http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
    To get an idea of the energy involved,
    http://www.railpictures.net/viewphoto.php?id=176187. The tanks on this locomotive arn't really that big. Well, weren't. Note the bent running board. The channel at the edge was maybe 4", maybe 6". The doors and engine compartment structure were also bent up (look at the roof... it is humped).
    National City CA
    1,086
    Quote Originally Posted by Iron Head View Post
    Better yet, hydraulic cylinders, steam lines, on and on and on.
    Not saying you can't. Liability is one issue. And I'm not referring to damage to your own home how about the guy next door. If you house catches fire that tank if pressurized and no safety valve will end up a couple of zip codes away. Same goes for hydraulic cylinders. Are you willing to bet your life on your welds. Training, experience, those are the qualities of the guy i want welding my steam lines, hydro cylinders, and air receivers. But then when you take into consideration cost of materials and fab time. Along with learning how and why the tanks are designed the way the are. Add in the threaded bung fittings and safety valve it starts to add up. and to me it just ain't worth it. Oh did I mention I'm a cheep SOB too. and I still wouldn't make an air tank that big even at half the cost of new.
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    National City CA
    1,086
    Quote Originally Posted by enlpck View Post
    I did say 42 TONS of potential force
    4,446
    I don't know how much 30 inch domes cost for that pipe but I would bet plenty, more than a tank. I bought a 12 inch for an oilfield job a while back and didn't look at the price, just passed it on but for it and a couple other parts it evidently was worth it to send someone on 2 hr road trip. The welding wouldn't worry me as much as some of the other design factors but the 3/8 wall pipe would certainly be adequate, not with flat ends though. I don't get too uptight about certifications for a lot of jobs but we usually know the design is overkill to some extent.
    Same with trailer hitches, I look a lot at the customer, I have refused to do them when I didn't feel the person or truck was unsafe such as a broad with a 78 Ford pickup with one working brake wants to hook on a 4 place horse trailer to this piece of crap, no tail lights or working brakes, I am not working on that truck period.
    4,446
    My Bud Cliff is another matter, would do any job he asked as he is fussy about his stuff, in good condition and takes every reasonable human effort to take care of it.
    Traer, IA
    317
    Default Well.....
    I wouldnt do it - but I'm not a welder by trade either. I agree with the others that you definately dont want to use flat ends
    Attached are some pics of a compressor my Dad built me about 10 years ago. He used weld caps on the ends, pop off valves etc....
    Now before anyone jumps all over me, he was a pipe welder with all the certs and mostly welded high pressure steam lines for the local university and John Deere. He's retired now, but still the best welder I know of. I'd bet my life on that compressor never letting go, but on the same hand feel very very nervous filling a purchased portable air tank with 90psi, built by people who build them day in and day out (probably in China). I had a buddy on the receiving end of a purchased air tank that decided to let go. Wasnt a pretty site - the tank basically wrapped around his head. 10K later in plastic surgeory he still looks like Herman Munster (minus the bolts). Let me know if you would like any other pics of the tank. I'll get a picture of the tank that blew up on him when I get a chance - he kept it as a little reminder since the only thing he remembers is starting to fill it, then getting the hospital bill
    National City CA
    1,086
    Yep
    Here in California any pressure vessel larger then 10 gal has to be inspected every five years and be ultrasonically tested for signs of corrosion by Cal Osha. I don't remember off the top of my head but I think if the vessel lost 5% of it's wall thickness in any location the tank had to be retired. CalOsha has their own division just for pressure vessels.
    As for the small home compressors having a service life it's most likely due to the lack of an automatic drain. Without one the tank will eventually fill with water.
    First place I ever worked for had troubles with their air compressor. It wouldn't hold any real pressure or should I say it was cycling quite often like there was a high demand of air. Well no one listens to the new guy. And they proceeded to unbolt the compressor. and move it out and bought a replacement. turns out the compressor was half full of water. No drain on the tank no cycling air dryer nothing just a ball valve down stream of the tank in the air piping system
