    May 2008
    Default Branding Iron Heaters, Porpane
    Looking for input, ideas, plans for a shop-built branding iron heater. (for personal use) Have a piece of 8" sch40 pipe and mat'l for legs, just wondering if someone else has built something like this in the past and would like to share some tips. Also, a little puzzled about the burner I should use. Recommendations? Buy a premade burner or tips to fab one up.
    Indiana
    541
    May not help, but it sounds like the gas forges I have seen. Some even make their own. I have even seen the burner made out of pipe with holes drilled in it and capped on the end, with a gas grill regulator on the tank. Sounds kinda dangerous to me though.
    Try searching on the net for homemade forge.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Also try searching the internet for pottery kiln construction. At one point I was going to do sand casting and was looking at building a kiln like oven to melt the steel
    Millermatic 350P
    Dynasty 350DX
    Trailblazer 302
    Spectrum 2050
    Spectrum 375 Extreme
    Wartburg,Tn
    575
    yes a gas forge would work. here are some ssites for ya to look at
    www.iforgeiron.com
    www.anvilfire.com
    and google gas forge plans .
    Inferno Forge
    Chris
    Texas
    279
    You could go this route, tis a mudbug cooker burner uses 3/8" nipple TBE w/a cap drilled 1/16" hole in it's top, cocked to the side so the flame hits the vert. pipe, uses no regulator. During the winter SIL stands a short pc. of 12", maybe 16" pipe in place of the cook pot and surves as a heater for his two bay muffler shop.
