i was wondering about this exact same topic for painting utility trailers. Is there any product like tremclad rust paint where you can just spray bare metal? Or better yet, anything you can spray through a hvlp gun?
Hopefully someone knows of a one shot process.
P.S. Sanding isn't an option.
Results 11 to 20 of 21
05-04-2008, 01:38 AM #11
- May 2007
- 20
05-04-2008, 05:22 AM #12
Sherwinn Williams DTM.....direct to metal
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
05-04-2008, 09:24 AM #13
With over 500 trailers built to date, the best thing I have found is plain ole' Rustoleum Rusty Metal Primer and a top Coat of Rustoleum Gloss Enamel. Cost is about $25.00 per gallon for each and about $10.00 for the thinner.
All I do is wipe trailer down with thinners, cut the primer with about 20% thinner and shoot one good coat. No sanding of primer is needed. Mix paint the same way with about a 20% reduction with thinner and spray a couple of coats. The wetter you can spray it the more gloss it retains and smoother it lays out, spray it dry and it will look dull and rough.
I use both siphon feed and HVLP spray guns with equally good results either way. The paint holds up for years and is easy for a customer to get touch up when needed. I've got a few customers with well taken care of trailers that are 5 years old that still look almost new.
I have had some people tell me that Rustoleum is cheap junky paint and a poor choice but I swear by it for commercial or industrial use. DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
05-04-2008, 10:56 AM #14
- Dec 2007
- alabama
- 718
05-04-2008, 12:30 PM #15
- Dec 2007
- National City CA
- 1,086
Don't degrease with mineral spirits. That's a petroleum base solvent and leaves a oily residue behind.
Either degrease with a water based degreaser i.e. simple green or use Acetone, xylene, MEK, Lacquer thiner or something like that. these will not leave a residue behind and your paint will stick much better.
No as for surface prep. Usually just cleaning up the splatter around the welds degrease with above chemicals prim and paint.
The hot rolled finish is actually pretty rough and provides a good surface for paint to adhere to.
We painted over fifty machine bases a year this way and never had one come back for paint pealing. and we did do a rebuild on a machine that was ten or so years old. the paint was worn but it was not pealing we just sanded the worn areas and repainted to whole thing.Last edited by kcstott; 05-04-2008 at 12:33 PM.
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Auto shades are for rookies
www.KLStottlemyer.com
05-04-2008, 05:53 PM #16
- Apr 2008
- pine city mn.
- 20
when i powder coat or paint an odd part that cant be blasted i get some preclean from eastwood.com
05-04-2008, 06:35 PM #17
05-04-2008, 06:48 PM #18
Voigt Precision Welding, Inc.
Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
2007 Silverado 2500HD (tow vehicle)
2000 Camaro SS (Race car)
05-04-2008, 10:32 PM #19
05-05-2008, 06:42 AM #20
I threw rustoleum out at the begining LOL
