Here is a F8000 truck frame that I extended 24''. Welding was done with a Trailblazer with RC12. There is a insert bolted in as well.
Results 1 to 10 of 10
Thread: Ford F8000 frame extension
05-01-2008, 03:17 PM #1
- Nov 2005
- Buhl, Idaho
- 53
Miller Trailblazer 302
Miller 12 RC wire feeder
Miller HF 251D-1
Miller 175 wire feed
05-01-2008, 07:31 PM #2
whats it for?
looks good to me.........whats the truck gonna be for? i.e. why did it have to be stretched? just curious......
1 BEST 6 Y/O HELPER IN THE WORLD
2 VICTOR O/A TORCHES
LINCOLN SP 175 PLUS
4 EACH 20 TON JACKS
SEVERAL LESSER TON JACKS
SEVERAL GRINDERS
LOTS OF HAMMERS MISC SIZES
BIG PILE OF MISC TOOLS
CLASS A CDL'S
C7500 FLAT BED
4 TRAILERS
HOME MADE GANTRY CRANE
SOME GOOD COMMON SENSE (I THINK
TRACTOR WITH NEW HEAVY DUTY LIFT POLE -- FIND MY THREAD
6 GOATS, 1 DOG, 1 DONKEY...
ON AND ON AND ON...
05-28-2008, 07:37 PM #3
- Jul 2007
- 4
I do not know why you did this, But the last time I saw something like this, it was in two pieces in the middle of Miami Int. Airport. what you did is a NO NO.
If you know any think about large trucks, You do not weld on the frame. Check with any good truck shop. Most trucks have a sticker and some are stamped on the frame Do no Weld.
05-28-2008, 07:50 PM #4
Looks good, fish plates are good idea, looks like it may have cut on an angle.
Tim Beeker,
T-N-J Industries
(my side bussiness)
Esab 450i with wire feeder
HH135 mig
Miller aircrafter 330 - sold
Marathon 315mm coldsaw
table saw
Dewalt cut off saw
Sand blast cabinet
lots of hand grinders
Harris torch
beer fridge
05-28-2008, 09:53 PM #5
- May 2008
- Belle Plaine Iowa
- 233
Truck frames are routinely cut and welded, lengthened or shortened. Always cut on an angle and double plate. It should last for many years and maybe a million more miles but keep an eye out for any cracking.
05-28-2008, 10:22 PM #6
05-29-2008, 11:50 AM #7
- Sep 2005
- S.W. Pennsylvania
- 2,249
What I've seen done differently that I like is to have the brace plates bolted on or roset welded to avoid having a continuous bead of weld going across the frame. Of coarse the frame is still welded across the slanted cut but its covered by the plates.
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
05-29-2008, 06:10 PM #8
I'm with Don, and strongly disagree with your statement. Yes, the trucks DO have a sticker on them advising against welding ON THE FRAMES. It does NOT say that the frames cannot be welded. Totally different thing.
Originally Posted by jamilone
That warning is just to get the attention of the Cerebral Juggernauts and Backyard Wanna-bees that try to attach chain hangers and fenders (for example) to the frame by welding them on.
I shorten them, lengthen them, weld bumpers to them, weld rear tow aprons, and ramp/roll assemblies to them and everything stays where I put it. Now, that being said, my preference for most of the accessories (bumpers & aprons) is to bolt them on.....But, the customer is paying the bill. As long as I can meet his/her specifications with a sound and safe welding procedure, it gets done.
End of story.
FYI.... Frames are not "Stamped" as it creates stress risers, and can lead to cracks and failure.Last edited by Black Wolf; 05-29-2008 at 06:12 PM.
Later,
Jason
Professional Spark Generator by Trade.
05-29-2008, 08:39 PM #9
- Feb 2005
- N.E. SD
- 1,368
06-01-2008, 03:18 PM #10
The only thing I diddnt like is the fish plate being welded on across the frame.
I would have only welded across the frame at the splices.
I would have put an inner channel in and let it go beyond the splice and all of my welds would have been parallel to the frame.
Other than that Im sure its a good weld.
I would also like to add something I saw on tv today, They were doing a lift kit on a jeep where welding was required and the guy on TV said dont forget to disconnect the battery before welding and I just had to chuckle.
What he should have said was to keep the ground near where your welding and not on the alternator bracket when welding at the back.
Ive had alot of my customers ask me to also dont forget to disconnect the battery before welding.
I always knodd and say OK.
Ive welded on well over 400 trucks and motor hmes over the years and still havent bought one computer.
If your going to disconnest the battery then you better remember to go through and find and diconnect all the ground straps as well.
