Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: arc blow
  1. #21
    4,435
    I use 6011 these days and a while back I came across 10# of 10 I must have bought somewhere along the line. They had been laying on same side for so long they burned funny. They were in a plastic Hobart box but they hadnt moved. It appeared that maybe some of the heavier elements in the coating had "sagged" around.
  2. #22
    Sep 2012
    seaford de
    406
    Some 6010s are really bad for going bad.. Like the lincoln 5p, they don't last very long at all. I won't even buy them anymore.. I buy the 5p+
  3. #23
    Sep 2009
    Canada
    189
    Arc blow.
    The phenomenem of magnetising your work while electric arc welding causing your arc to wander.
    I run into it frequently if I'm running 1/8 7018 flat and trying to run real high amperage. In this case, it is self induced. I will run 1/8 7018 flat up to 160 amps on ocation. This often will induce arc blow. I've tried all the tricks, welding toward the groundclamp, wraping the ground cable around the work, you name it. Only thing that works is turning down the amps. No ac weld current on a dc only industrial welder.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
  4. #24
    Jul 2010
    378
    Quote Originally Posted by snoeproe View Post
    ...I've tried all the tricks, welding toward the groundclamp, wraping the ground cable around the work, you name it. Only thing that works is turning down the amps. No ac weld current on a dc only industrial welder.
    Sometimes if I get arc blow at the edge of a piece I'm welding, it seems like if I tack another larger piece of steel to the edge of whatever I'm welding on – in other words, tack it to the workpiece on the opposite side of the electrode as the direction the ground clamp is – I can reduce the arc blow that way.
