Results 1 to 10 of 14
    Kris K Guest
    Default Old Miller welder?
    I 've been looking around the site alot latley learning alot from others post and, desided to join.
    First off I have a question I'm looking at this older Miller welder on a local classifieds site and, I have nowIdea what it is nether dose the owner. I was just wondering if anyone hear could help out. I know it's a Miller arc from the pic's but what I don't know is if it's just AC or AC/DC. Also is this welder any good. He's asking $100 for it. Any help would be great thanks.
    Mar 2007
    511
    to me it looks like it might be ac/dc cause of the three lead hookups at the bottom but im not shure. do u have any other pictures? it could also be an inverter cause of the hookups to i think.
    welding...its awsome
    Jun 2006
    Calgary, Alberta
    377
    Looks like a Miller Thunderbolt 225 -250 amp AC machine. A machine with AC and DC capabillites would probably have more lead terminals. I used to own the ac/dc version, it was a good stick machine for all around uses. $100 isn't a bad price if it comes with the leads. The newer version of that machine costs $389 right here on the Miller site.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    Aug 2006
    near rochester NY
    9,881
    welcome
    any chance of better pic's or ask him to read the plate on the back, he should be able to find out if its ac or ac/dcthe lil stick boxes are about indistructable so if it sparks it bound to be fine.
    Oct 2005
    Bulverde, Tx
    1,244
    Definitely straight AC. It will have a work plug and an AC high and AC low output plug.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Nov 2006
    Lake of the Ozarks MO
    3,548
    I have one just like that I bought around 1980 new and I still wouldn't take a hundred bucks for it even tho I never use it. Should be a good deal.
    Dec 2006
    Alaska
    732
    Miller Thunderbolt my first welder ac only work and hi low $100.00 smoking deal.
    You cant brake it
    Tj
    TJ______________________________________
    Mar 2007
    ****inson ND
    557
    Talking
    He!! of a good deal! Old miller thunderbolt straight AC hi/low and work plugs. I got shocked working on one of those before. I was cleaning one out once and replacing the terminals with cam lock conectors when some dumbazz decided to plug it in! (you know who you are if you ever read this.) My arm was limp for 2 days before I regained fealing in it. It was wired for 220 so I was prety lucky thats all I ended up with.
    Apr 2007
    106
    Quote Originally Posted by Anti-GMAW View Post
    I'm sure you exercised discretion but there's no jury on earth that would have convicted you if you did what that guy deserved.
    Good reminder for everybody though -- lockout/tagout. Most guys I've worked with are careful of others but there's always at least one on site without a clue. Ah crap, I guess I've done my share of stupid things. OK, forgive and forget.
    Jun 2006
    Calgary, Alberta
    377
    Phila, you're absolutely right. Lock it out, tag it out, or wrap a whole roll of duct tape around the plug. What ever it takes to keep the equipment from being energized.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
