Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: scrap grapple
    S.W. Pennsylvania
    2,250
    I had the opportunity to watch some guys in AZ using a lance to cut a dragline bucket in half. It was really impressive, filled the valley with red smoke.
    To all who contribute to this board.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Apr 2008
    pine city mn.
    20
    on the payloader bucket they use them roll pins to hold on the quick change replaceable teeth. you need a good sized punch with some meat to it and a 4lb hammer. it takes some time and your forearm burns from swinging the hammer but they come out.
    Aug 2007
    arkansas
    781
    i ran a service truck for a dealership for a few years on heavy equipment.... i have beat and beat and beat on those stupid roll pins...... i HATE them!!! but, yeah, i have figured out a secret...... i took a tapered punch for an air hammer, clipped the point off, then turned it down on the lathe until it was the exact dimensions of the pin (not the hole) and chuck it into a good air hammer and pull the trigger, watch the sparks fly...... and the pins too
    welder_one
    www.sicfabrications.com
  4. #14
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Looks like you did a good job on it.
    Bummer about the water, why does that type of stuff ALWAYS seem to happen???
    One quick suggestion, pick yourself up a small galvanized pail and throw all of your rod butts in that. Helps keep your work area cleaner, saves cleanup time once the job is done (or even when your getting setup) and you can use it to put tools in to cut down the trips too and from the truck.
    at home:
    2007 302 Trailblazer with the Robin FOR SALE
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
  5. #15
    May 2009
    The Colorado Gas Patch
    185
    Quote Originally Posted by grnxrymnky View Post
    p.s. my welder is not strapped to the trailer, it's bolted down.
    Well then use that extra strap and attach the O/A bottles to something (PIC 4)... All it takes is just one time ... Just like whatever happened off shore on the platform before it blew!
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Looking at CNC Plasmas
    It's Miller Time - Get Back To Work!
  6. #16
    Dec 2009
    722
    Good job. Does the muffler on the welder is for pollution or sound
  7. #17
    Nov 2008
    Atl, Ga
    371
    i once heard of some rods that once they are lit they burn right through just about anything. if the guy wasn't pulling my leg they might be worth checking in to. does anyone out there know anything about them?
    Arcair "Slice" torch works sort of like a thermal lance but on a smaller scale. Will burn through just about anything -rust, crud, cured concrete included. They are absolutely nasty to use though, especially with the short rods - definitely wear full leathers! I prefer regular CAC for most stuff but when burning out out pins, you can poke straight through with exothermic (slice) using coated rods. Keep in mind all the molten metal being burned will be shooting out of the hole directly towards you until you pierce through.
    You can light them with a torch same as you would a thermal lance, or can light them by hooking up to a welder at low current or Slice battery ignition box and scratch starting them as you would with a welding rod. Pure O2 runs through the rod and blows out the end. They don't work with compressed air like CAC does. The higher the O2 pressure the more flying molten metal they make. Stock up on extra cover lenses and burn ointment, you'll probably need both!
    2007 Miller Dynasty 200 DX
    2005 Miller Passport 180
  8. #18
    Apr 2008
    JACKSON, MS
    88
    Default extra muffler on bobcat 225 nt
    Quote Originally Posted by Daniel View Post
    i wanted it to cut down on the noise, but i couldn't really tell a difference. it's now back to stock. i'm thinking about selling it and getting an xmt 350 unit. i just don't hardly ever go mobile. i did the one mobile job on the scrap grapple, but that's it. everything else i've done has been here at my shop. there are some things i'd like to produce multiples of and i'd go to the shop more after i'm home from the hospital, but engine noise late at night doesn't go over well with the neighbors. this guys operation seems pretty sweet..... http://www.millerwelds.com/resources...w-wire-feeder/
    1 BEST 6 Y/O HELPER IN THE WORLD
    2 VICTOR O/A TORCHES
    LINCOLN SP 175 PLUS
    4 EACH 20 TON JACKS
    SEVERAL LESSER TON JACKS
    SEVERAL GRINDERS
    LOTS OF HAMMERS MISC SIZES
    BIG PILE OF MISC TOOLS
    CLASS A CDL'S
    C7500 FLAT BED
    4 TRAILERS
    HOME MADE GANTRY CRANE
    SOME GOOD COMMON SENSE (I THINK)
    TRACTOR WITH NEW HEAVY DUTY LIFT POLE -- FIND MY THREAD
    6 GOATS, 1 DOG, 1 DONKEY...
    ON AND ON AND ON...
  9. #19
    Apr 2008
    JACKSON, MS
    88
    Quote Originally Posted by Pass-N-Gas View Post
    if i remember right, they did end up tied off. seems like one of the hands came by and said something about it. it takes a village (everyone else) to raise a child (me) and safety is number one.
    of course everyone has a friend that blah blah blah....but i have a friend with a pretty big operation in columbus, ms and they had a bottle get loose, fly around the shop, bounce off of anything that it didn't knock out of the way, go through the roof and end up somewhere in the cross-tie plant yard behind them.
    LINCOLN SP 175 PLUS
    4 EACH 20 TON JACKS
    SEVERAL GRINDERS
    CLASS A CDL'S
    C7500 FLAT BED
    4 TRAILERS
    ON AND ON AND ON...
