Results 1 to 10 of 19
Thread: scrap grapple
    Apr 2008
    JACKSON, MS
    86
    Default scrap grapple
    hey y'all! thought i'd post some pics of the side job i did saturday morning. i went to this scrap yard looking for some i-beam pieces, handed him a card and asked if he would call me if he got any. he looked at my card and asked for a quote on putting teeth on his grapple.
    the only thing that scared me was the pins that were rusted in place still in the old adaptors, and how long it would take to get them out--i guess that's what you call the unkown factor in bidding a job. anyway, i gave him a price and he said to go ahead. five of the seven retainer pins eventually banged out with a big punch and a 2 lb hammer. the other two i had to cut out with a torch--lots of spatter! they were roll pins, spring steel, so they wouldn't drill. i even tried heating the adaptor to try to expand it a little, to no avail. any suggestions for the future would be appreciated.
    enough blabber-jabbin, let's get to the pictures!
    1 BEST 6 Y/O HELPER IN THE WORLD
    2 VICTOR O/A TORCHES
    LINCOLN SP 175 PLUS
    4 EACH 20 TON JACKS
    SEVERAL LESSER TON JACKS
    SEVERAL GRINDERS
    LOTS OF HAMMERS MISC SIZES
    BIG PILE OF MISC TOOLS
    CLASS A CDL'S
    C7500 FLAT BED
    4 TRAILERS
    HOME MADE GANTRY CRANE
    SOME GOOD COMMON SENSE (I THINK)
    TRACTOR WITH NEW HEAVY DUTY LIFT POLE -- FIND MY THREAD
    6 GOATS, 1 DOG, 1 DONKEY...
    ON AND ON AND ON...
    Apr 2008
    JACKSON, MS
    86
    Default more pics
    of course, as soon as he drove the boom up into the bay, the bottom fell out. rain water ran down the boom and i had to do the whole job standing in water. as soon as the rain quit, i bummed a push broom and swept out most fo the water. blah, blah, blah!!!! i still had fun and finished the job under my estimated time frame.
    p.s. my welder is not strapped to the trailer, it's bolted down.
    LINCOLN SP 175 PLUS
    4 EACH 20 TON JACKS
    SEVERAL GRINDERS
    CLASS A CDL'S
    C7500 FLAT BED
    4 TRAILERS
    ON AND ON AND ON...
    Jul 2007
    Lancaster, Pa
    431
    Nice job, as far as driving out the drift pins next time, get a good penetrating oil or silicone and spray them up really good. Next find a rod the same diameter as the drift pin so it cant slip down inside the pin as your beating on it, a few good whacks, it should pop out. I did numerous pins like this on a backhoe and they always came out without using a torch.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Sep 2007
    N. CA
    7
    If the roll pins are hollow tubes, clean the packed dirt and crud out of the center of the pin first.
    This seems to allow the pin to collapse a little.
    It makes removal easier.
    K.
    Miller giveth,
    Victor taketh away.
    Apr 2008
    JACKSON, MS
    86
    Default roll pins
    these pins were coiled all the way to the center. i did try to drill one but being spring steel(?) the new drill bit just squeeled and died. next time i'll surely try the penetrant spry and i'll try using a small (1/16") bit to drill the dirt or corrosion from the center. they both sound like good suggestions--thanks!
    i once heard of some rods that once they are lit they burn right through just about anything. if the guy wasn't pulling my leg they might be worth checking in to. does anyone out there know anything about them?
    LINCOLN SP 175 PLUS
    4 EACH 20 TON JACKS
    SEVERAL GRINDERS
    CLASS A CDL'S
    C7500 FLAT BED
    4 TRAILERS
    ON AND ON AND ON...
    lancing rods are nice. and they do exist.
    coiled pins stink
    the best I ever saw was a chunk of round stock that had a hole sized for the punch. a real close fit . it got welded on over the pin and then you drove the pin out. worked really well by keeping the punch and the pin aligned really well.
    you can also dead short thru the pin heating it cherry red then quench and drive.
    Mar 2006
    Queens NY
    1,547
    try soaking with Kroil.
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Feb 2008
    North of Phila. PA
    404
    We use a Broco torch for underwater cutting. The rods will burn thru anything, steel, brass, concrete, wood. They are not cheap and use a special holder that also supplies O2 thru the rod. I doubt these would work well for this application though.
    Mar 2007
    Mobile,Al
    108
    I agree the Kroil oil And maybe a 4 lb beater and punch,The Lance rod would be no good unless you wanted to cut the grapple into pieces.....
    Apr 2008
    dallas,tx
    207
    I got to use a thermal lance on a high security safe. the wall of the safe was 5" total thickness consisting of 3/16"inner and outer steel, 1/4" of manganese steel, high density concrete reinforced with stainless steel fibers and some other steel thrown in for good measure. I was able to burn a hole through all that in about 40 seconds, which was about the same time the rod lasted. It was a mess, vaporized concrete and spatter all over the place. lof of fun though, I'll see if I can find pics of it
