Frank,
The Shenandoah was built to withstand 4 meter seas and Force 8 winds, so she is theoretically a coastal vessel too. I brought her out the Thames Estuary and across the English Channel, east up the coast of France to Nieupoort, Belgium, where I entered the inland waterways.
I would not do it again.
There is no longitudinal stability in a flat-bottomed boat with no keel. She is built that way because draft (or lack of draft) is very important. If a keel were designed into her hull, she would handle quite differently in a sea. As it is, on canals she has a tendency to "skid" around tight turns. I know about it and deal with it and it isn't a problem.
As for American boatbuilders, there probably are many who would tackle the job. All you would need would be the plans, the rest a good weldor / welder could accomplish.
Results 11 to 20 of 20
Thread: Steel Boatbuilding
04-29-2008, 06:19 AM #11
Capn' Dave
Plying the canals and rivers of France. Plunder, wenches, good wine...!
05-07-2010, 11:46 PM #12
- Feb 2010
- 33
Old thread I realize, but I thought I would post some links to plans or kits for Dutch-style barges or somewhat similar designs:
http://www.euroship.hu/index.php?pag...hu&language=en
http://www.dutch-barges.net/
http://www.selway-fisher.com/Mcover30.htm
Also, although not listed on his website, in some email correspondence with Bruce Roberts he said that they could also supply plans or kits for a Dutch-style barge. He emailed me a little bit of material on a nice looking design titled "Johanna 1350". Here is his website.
http://www.bruceroberts.com/
Bruce Roberts says that his boat designs to conform to RCD B classification, which means that they are suitable for offshore conditions with waves up to 4 meters and Beaufort force up to 8. (http://www.hpi-uk.com/inspection/rcd...directive.html)
05-08-2010, 06:55 AM #13
- Dec 2009
- 7
boat
I built a 26' aluminum boat for fishing off the coast of Vancouver Island. Took me 2 years of evening and weekends to complete it. Was a lot of hard work but fun. Now I have a boat that will last my lifetime and most of my kids.
I tried to up load a pic but for some reason it would not upload.
05-08-2010, 08:41 AM #14
Boat Building
Yes, welding the hull is very feasible. In boating, just like racing, weight is paramount so go aluminum if you can. You can even weld the aluminum with your MIG. Just use straight Argon as the shielding gas. It takes allot of practice though to lay down a pretty bead.
To keep the weight down even further use thinner gauge material and add some ribs. Another thing to consider is that most boats built today still float when you fill them up with water. To achieve this quality add a secondary layer of aluminum/wood/plastic on the inside of the hull filled with foam.
Happy boating!!!
Scott
Fab Manager
http://www.welders360.com/
05-08-2010, 03:50 PM #15
- Mar 2010
- 459
Build one for fun, but there are much better ways to get a boat in this economy. Repos and desperation sales abound.
Here's the best forum I've found. I don't boat, but had some particular questions they answered. Great place, lots of info:
http://www.boatdesign.net/forums/boat-building/
05-08-2010, 06:46 PM #16
- Dec 2009
- Williams Lake, British Columbia
- 722
05-08-2010, 06:47 PM #17
- Dec 2009
- 722
05-09-2010, 12:42 AM #18
- Feb 2008
- Guam
- 177
When I was salmon fishing in the 70's, n.cal and orgeon, I was impressed by the fleet of orgeon dories. Simple design mostly built out of plywood and then fiberglassed or aluminum. I've seen them little buggers fishing some tuff weather of cape mendicino and cape blanco
05-09-2010, 05:03 PM #19
05-09-2010, 06:17 PM #20
- Oct 2007
- Cave Creek Az
- 803
Hey signwave, there are 2 Ns in Annals, you might want to edit your post as I hate to think of anything stored in the prior.
