Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. #21
    Nov 2006
    toronto,ontario
    90
    Default re y connector and repair of keg
    hey usmcruz,hows it going my friend,if i can offer you some advice try to stay away from y connections into the same hose that feeds your torch, it will not regulate evenly or precisely and you may open a different can of worms altogeather.if you can set up a seperate bottle for purging with its own lines and regulator. as for youe patch, for a proper repair, and it may not be as critical(not sure if the kegs hold much pressure ,but it would be best to cut out any cracking etc ,almost make it a boxed shape cutout and then fit the same gauge of metal into the opening secure it flush on one end, then tack it and move along keeping the material flush all alonguntil you have tacked it securely all round. hen go around and add tacks everywhere as stainless has a bad tendency to shrink and then go for doing your root pass, cool between and fill and cap passes afterward but try to let the keg cool between passes. ever need any help just drop me a line bro, hope that helps and i have all kinds of stainless pics of my work so youll feel confident in knowing my advice is good.,otherwise they wouldnt let me weld in the nuclear station i guess lol
  2. #22
    Jan 2008
    In wal-mart
    460
    man of steel, thank you very much for your help. Its too late, I already installed the Y connecter. Is there a way to make it work?, I also picked up a Miller Foot pedal control today/1/16" tungsten and collets, and let me tell you that was the best money I spent on the Tig side of the house. I picked up the finger control and tried it and didnt like that the current didnt return to zero when I lifted my hand off the tumbler like when you lift your foot off the pedal control. I returned it, and got the foot control instead.
    The guy at the welding supply store tried to sell me on the finger control, saying that I would need it for out of position welding, but I told him If I need to weld out of position I'll put the foot control between my a$$ cheeks!! , he stopped arguing with me and sold me the foot pedal for some reason. Im pretty handy, and Im sure If I needed to weld out of position I could rig up something with the foot pedal.
    How can I look at your pictures?
    By the way did you get the last thing I sent you through PM?
  3. #23
    Oct 2007
    Mt. Clemens, Michigan
    277
    That dry ice idea is a good idea, I may have to try that sometime. I did a homebrew keg for a guy, I sealed up all the holes with tape and purged the keg with 75/25 from my mig welder. I worked pretty good. Here are some crappy pics:
    You should be able to do something like this with 3/32 tungsten. A nice fine point and good heat control and you are set. I've become a big fan of gas lenses recently too, you can increase the stickout and decrease the gas flow.
    As far as cleaning the inside with nitric acid, I'd really like to get a hold of some but can't find anywhere local that sells it. If anyone has any suggestions on where to find it and how to apply it I'd be all ears
    -Josh
  4. #24
    Jan 2008
    In wal-mart
    460
    Quote Originally Posted by jdustu View Post
    Those welds look pretty good Josh. I got a question though, if you purged the keg, and taped it off, how did you keep the argon from escaping through the 1/2 inch coupling, and around the 1/2 inch coupling you were welding up.
    As far as the acid goes, you can either leave a thick paste of barkeepers friend which is used to reppasivate Stainless Steel, or you can use a chemical called "ACID #5" from 5 star chemicals. Its made for stainless steel, and instead of diluting the acid paint it on straight, but wear gloves, because it will eat you to the bone.
  5. #25
    Oct 2007
    277
    Quote Originally Posted by usmcruz View Post
    I set the keg flat on my bench, and I set a heavy bolt and a large washer into the boss to cover the hole. I'd do that on the "hot" one, and tape off the rest.
    I'll have to check out that Acid #5. I've got some of the barkeepers friend, but I didn't leave it on very long. I may try that again too.
    -Josh
  6. #26
    Oct 2007
    277
    Here are a couple pics he sent me of the inside of the keg. It wasn't a perfect shield, but it worked ok. He had cut the holes before he gave it to me and they were oversized, so the gap didn't help matters.
    -Josh
  7. #27
    Jan 2008
    In wal-mart
    460
    I dont let any of my customers cut the holes. For the first 3 jobs I did on kegs the holes were already cut, and pretty ugly looking. From then on out I just tell them to leave the keg alone and I will do the rest. I use a 5/8 conduit punch, and then I open the hole just a little bit with a dremel to get a tight fit that will keep the fitting in one place so that I can tack it up. Works pretty good, and so does the ghetto back purge assembly. You can take the man out of New York, but you cant take the New York out of the man.
  8. #28
    Oct 2007
    277
    Yeah, I usually like to fit everything myself. I do a lot of repair welding at my fulltime job, and most folks don't have a clue how a joint should be prepared. But they try, and they can't figure out why I need to redo it
    Quote Originally Posted by Iron Head View Post
    Just have to ask, what is a ghetto back purge assembly?
    I think he's referring to the solar flux.
    Edit: This is what he is referring to -http://www.millerwelds.com/resources/communities/mboard/showthread.php?t=12989
  9. #29
    Jan 2008
    In wal-mart
    460
    You like my back purge assembly, it could be yours for 10 simple payments of $1, and if you call now within the next 3 minutes I will even throw in the duct tape attached to it free of charge!
  10. #30
    14
    FWIW, the sugaring I have seen is from overheating. Overheating causes the carbon to precipitate from the SS. You can see this by taking a coupon of SS and running a bead using a little too much heat. Then run another bead with less heat. Depending on the thickness, you may be under 50 amps. If you can use pulse, you will run cooler. Also, they make rods with an "L" designation, which designates low carbon.
