Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. #21
    Mar 2008
    Baltimore, Maryland
    315
    Quote Originally Posted by welder_guy View Post
    Did you get a black soot covering or surrounding your weld?
    I got black soot covering few of the welds when I got out of position. Got most of the soot in the corner and under the tube area.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
  2. #22
    Deltaville, VA
    2,239
    Tasslehawf,
    How the heck do you TIG weld with those gloves (shown with switch)? They look like something I'd use if I was running a stick at 300A. Must be a real beach to feed filler with them on.
  3. #23
    Austin, TX
    621
    Tasslehawf,
    I like to burn the filler rod right down to the end and I used to burn my fingers, so I got thicker gloves. I'm just used to it now, I guess.
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
  4. #24
    Oahu, Hawaii
    2,469
    yeah, my foot pedal that came with the contractor's kit for my dyn200dx was plastic also................
    I'm not late...
    I'm just on Hawaiian Time
  5. #25
    Mar 2008
    Baltimore, Maryland
    315
    The big clunky pedal works and so does the new machine. Is it supposed to be that loud right? It is a louder then my MM180 and a little higher pitched sounding when just turned on at Idle.
    James
    20Ton press
  6. #26
    CT.
    333
    Quote Originally Posted by StillBoostin View Post
    James
    Yes the starship space noise is normal with the 200DX at idle. I am told it is the DVI setup.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
  7. #27
    Austin, TX
    621
    Quote Originally Posted by TJS View Post
    T.J.
    Maxstar does it too. I do like how you can hear when it counts down from the duty cycle rest (?).
  8. #28
    Mar 2008
    Baltimore, Maryland
    315
    Just put the final touches on the cart will get pics up tomorrow. Gonna get a strap for the Dynasty, or I was thinking of using 1/2" Al round stock and welding next to the Dynasty. Might look pretty trick. I would put some rubber over it or some rubber heat shrink to help from scratching or vibrations.
    James
    20Ton press
  9. #29
    Mar 2008
    Baltimore, Maryland
    315
    Finished the cart. I submitted it for the Miller challenge. Here are the final pics:
    20Ton press
  10. #30
    Mar 2008
    Baltimore, Maryland
    315
    Pics of the welds done with the SG100:
    20Ton press
